how to run ek ecu codes
under dash passenger side! lil plug just chilling there! Complete the circuit! IE: a wire in each hole but paper clips work! Then just count your flashes! then come back here search for ecu codes and walla!
EDIT: BY THE WAY CHECK THE FIRST FEW TOPICS IN THIS FORUM
Go to autozone and have them check it for you unless you have an OBD2 code reader. Then come back here and check the code. The area that you plug the code reader into is right under the dash on the drivers side.
MonKK
Nov 15, 2008 12:22 PM
jdmEK209
May 22, 2006 09:39 PM
