SI tranny on a DX engine?
First off, changing from a DX tranny to an Si is a good upgrade. Second, look @ the mainshaft end. Its the shaft on the tranny that will be slide into the clutch/flywheel. If it has 0 grooves after the splines on the very end, its most likely an 88. If it has 1, its an 89 and two are usually 90-91. Look at the end of the old trans and make sure your using the right mainshaft. The 88 trans all have a diff spline count on the mainshaft, whereas 89-91 are the same. You may have to change clutch/flywheel or change the mainshaft. Whichever is more cost-effective for you. - Darrell
ooo si trans on a DX. thats going to be quite a combo. I wonder how the DPFI is going to deal with the short gearing.... I have a DX, and I was going to put the SI trans on it. but I found it easyer to swap the motor. D16z6, obd1, P28, SI trans. That would make a nice street machine.
ahc'monracing
Jan 17, 2003 09:58 PM
dingusjt
Nov 22, 2002 05:59 AM
CRXtacy
18
Nov 5, 2001 03:10 AM
