b16 into an ef
anyone have links to this swap? i tried to search but you cant use 2 letters in search. also its obd 1 would this be a pretty much straight swap. im getting an entire jdm front clip. ty.
Considering how many swapped hondas that are out there, wouldnt you think that this is a Frequently Asked Question?
if so you can use this little post above thats called a FAQ...
https://honda-tech.com/zerothread?id=637661
:sarcasm off:
:sarcasm off:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baseballinmyass »</TD></TR><TR><TD CLASS="quote">anyone have links to this swap? i tried to search but you cant use 2 letters in search. also its obd 1 would this be a pretty much straight swap. im getting an entire jdm front clip. ty.</TD></TR></TABLE>
Little something I find useful in this situation. http://www.google.com. Go to advanced search, and at the top they have the return results only from domain, put in honda-tech.com. Then just search like normal. Google indexes all the stuff that h-t doesn't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baseballinmyass »</TD></TR><TR><TD CLASS="quote">sorry but i cant seem to find the faq button.</TD></TR></TABLE>
who said anything about a button you cumtwat...its a thread and i even posted the link. How much more easy can it get.
<-- sensing a possible tr0ll.
wow this is the second post for the same thing in the same day, DOESN'T THAT TELL YOU SOMETHING. There are countless posts out there about this. Try archive when searching!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Go to search, click on it, type in "swap", select the EF forum, and you're set. Also you might want to click on archives if you don't get that many good results.
