crx header clearence
Old Feb 6, 2005 | 08:27 PM
asilaydying1984's Avatar
Default crx header clearence
i have a crx with a b16 swap and i have a dynamic autosports 4-1 header, and the groung clearnece is horrible, its about 2 inches off of the ground, I was wondering if you guys know of a header that i could get that would have better clearence and still make good power, because i know this header is going to be hitting all the time thanks let me know?
brett
Old Feb 6, 2005 | 08:30 PM
EL Vap133's Avatar
Default Re: crx header clearence (asilaydying1984)
Hasport makes a header for our crxs/civics with a B-series motor that fits snug.
Old Feb 6, 2005 | 08:31 PM
EP3_05's Avatar
Look at the ANR header. Interesting 4-1 design that makes some decent power.
http://www.an-r.com
Old Feb 6, 2005 | 09:13 PM
Default Re: crx header clearence (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Hasport makes a header for our crxs/civics with a B-series motor that fits snug. </TD></TR></TABLE>
i just now checked that out, i wish i would have known about that before i purchased my header, i wont even be able to back out of the drive way with my header on without denting it
Old Feb 7, 2005 | 07:56 AM
any other ones?
Old Feb 7, 2005 | 08:05 AM
PaImportTuner's Avatar
same gain if not more. Tri-Y 4-2-1. 1 piece header look around make sure it has a 2.5" collector.
Old Feb 7, 2005 | 08:08 AM
PHOBIA's Avatar
well change it and sell it as soon as possible. i have a dc sports 4-1 and 2 of the 4 runners and dented half way shut.
Old Feb 7, 2005 | 08:13 AM
Default Re: (PHOBIA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHOBIA &raquo;</TD></TR><TR><TD CLASS="quote">well change it and sell it as soon as possible. i have a dc sports 4-1 and 2 of the 4 runners and dented half way shut.</TD></TR></TABLE>
ditto my Megan Racing 4-1 made 15whp tuned on a dyno jet and leaning out, and just like him 2 weeks later i dented the 2 bottom parts all the way in. flipped **** and hacked up the dented area and welded in new plates/halftubes and a thick *** skidplate which now instead of bending the outter 2 back in and helping me, the bump pushed the header back making it hit the block and bending the inner runner up. now i have 3 screwed up primaries.
Old Feb 7, 2005 | 08:16 AM
this is daidilus' car with 4-1 thats the outside view of height and here how much clearance any lower and his header would end up like mine.
Old Feb 7, 2005 | 11:39 AM
captainjdog's Avatar
Yea about once a month for me i wrap a chain around my header, chain it to a tree and back up to pull it back out away from my block. Tip of my exaust will be sticking out the back of my car approx: 2-3 inches, looks horrible. Untill I yank it back that is.
Old Feb 7, 2005 | 11:46 AM
daidilus's Avatar
yeah you have 3 options
1. stock height....
2. 4-2-1 header
3. AN-R
I chose number 1 because i also got tired of scraping everything up, people seeing my ladies business when she tried getting outa the car while dressed up, ******* up oil pans, and headers..that is number 3!!!!and i do not drive an autocross track to work!!
Old Feb 7, 2005 | 12:02 PM
wu tang's Avatar
Default Re: (daidilus)
my 4-2-1 header works great for me, and my cr-x is dumped
Old Feb 7, 2005 | 12:20 PM
daidilus's Avatar
Default Re: (wu tang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wu tang &raquo;</TD></TR><TR><TD CLASS="quote">my 4-2-1 header works great for me, and my cr-x is dumped</TD></TR></TABLE>
well umm we are talking about 4-1 headers.......a big...2-3 inch difference!!
Old Feb 7, 2005 | 12:54 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asilaydying1984 &raquo;</TD></TR><TR><TD CLASS="quote">
i just now checked that out, i wish i would have known about that before i purchased my header, i wont even be able to back out of the drive way with my header on without denting it </TD></TR></TABLE>
Why not raise the car?
Old Feb 7, 2005 | 11:19 PM
Why not raise the car? </TD></TR></TABLE>
the car really isnt that low and i dont like having it not lowered, this header just sits real low and bearly fit in the compartment, me had to do some modifications to the crossmember to get it to fit, i might just go ahead and get the comptech 4-2-1 header, does that get pretty decent clearence? also the collector is 2.5 inches right? also you said the anr header gets good ground clearence, is that in a crx?
Old Feb 8, 2005 | 03:41 AM
thatbluecrx's Avatar
my b16 crx has dc sport 4-1 ... ugh ugh ugh... the 4 tubes at the collector dont even sit on top of eachother anymore, its italiced if u would say... the bottom 2 pipes are more then half closed too.. btw.. im also stock height so, help this guy out with a nice clearing header to help me out too! )
ive seen ones that run 900+ that give clearance, anything cheaper out there i just wasted 300 on this dc POS to look good for 4 months lol
Old Feb 8, 2005 | 03:45 AM
Garrett's Avatar
Default Re: crx header clearence (thatbluecrx)
4-2-1 long primaries with 68 mm collector
or ANR
Old Feb 8, 2005 | 05:08 AM
daidilus's Avatar
Default Re: crx header clearence (Garrett)
http://www.x3racing.com/produc...9SI-C
that is the one that I have....it is pretty good on clearance...if you look at the pick..it is very very very snug to my oil pan, I would suggest a slight port to clean it up, and some ceramic paint...but what can you say for 119? and umm...daym...i could really feel the umph that things gives from 4000RPMs on
Old Feb 8, 2005 | 06:00 AM
thegreatwhitehope's Avatar
I've got a jdm itr header-I haven't bolt it up yet but I'm too worried. any suggestions?
Old Feb 8, 2005 | 06:07 AM
Default Re: crx header clearence (thegreatwhitehope)
sell the ITR header and get a good 4-2-1 1 piece
Old Feb 8, 2005 | 07:54 AM
well the only 4-2-1 piece i have heard of that has a 2.5 inch collector is the comptech, what are some others?
Old Feb 8, 2005 | 08:03 AM
slowpokesi's Avatar
Default Re: (asilaydying1984)
the jdm ctr header from 96- 98 is a good header, also has a 2.5 inch collector, i just sold mine for 50 bucks
Old Feb 8, 2005 | 08:40 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: (slowpokesi)
get the an-r compact header:
Old Feb 8, 2005 | 01:15 PM
Garrett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asilaydying1984 &raquo;</TD></TR><TR><TD CLASS="quote">well the only 4-2-1 piece i have heard of that has a 2.5 inch collector is the comptech, what are some others?</TD></TR></TABLE>
Vibrant,Mugen(Maxim Works) are the same and have 68 mm collector
Old Feb 8, 2005 | 01:43 PM
ls_vtec_crx's Avatar
ahh i'm one of those with the same problem.....my bottom two are smashed big time....i like the anr one but its hella expensive.....but im looking for another one....i like mines now because it has 2 o2 bungs on it already(DC) just like the an-r one....so if there's another one out there like that then lmk please...
