PM7 Ecu....Need more help..
Old Feb 6, 2005 | 07:43 PM
ivanson's Avatar
Default PM7 Ecu....Need more help..
Can i run a pm7 on a stock hf for
now until i get my swap without
messing up my engine??
Thanks reply back
Old Feb 6, 2005 | 08:07 PM
kulangot's Avatar
Default Re: PM7 Ecu....Need more help.. (ivanson)
yes, but it will run like ****...
Old Feb 6, 2005 | 08:09 PM
ivanson's Avatar
Default Re: PM7 Ecu....Need more help.. (sirq2u)
So. Its better stock for now? i mean
leave the PM8 instead?
Old Feb 6, 2005 | 08:12 PM
kulangot's Avatar
i would, i ran a pm6 in mine before the swap and it ran ok, but i would get a cel....
Old Feb 6, 2005 | 08:14 PM
ivanson's Avatar
How bout the PG7..Would it run
better on the stock...or PM6???
kulangot's Avatar
on stock...
Old Feb 6, 2005 | 08:17 PM
EP3_05's Avatar
Just run the stock ecu until you swap. There is no point to run a different ecu on the hf.
Old Feb 6, 2005 | 08:19 PM
ivanson's Avatar
Default Re: PM7 Ecu....Need more help.. (91civic)
Actually Ill get a high rev limit
on a pm6 or pg7...
Or im i wrong??....
mine currently is at 5500
Old Feb 6, 2005 | 08:21 PM
EP3_05's Avatar
Yes the rev limit will be higher but the hf doesn't make power that high.
Old Feb 6, 2005 | 08:25 PM
ivanson's Avatar
Thanks for the info guys....
Old Feb 6, 2005 | 08:26 PM
kulangot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic &raquo;</TD></TR><TR><TD CLASS="quote">Yes the rev limit will be higher but the hf doesn't make power that high.</TD></TR></TABLE>
keep it stock...tell you swap...
Eric Walls
14
Apr 1, 2011 09:20 PM
onlya1.1L
May 23, 2005 03:36 PM
crxSoldado
May 3, 2004 08:25 PM
CRX A4
13
Feb 7, 2003 06:01 PM
IamVtec
Aug 29, 2002 09:58 PM
