Will this rim size fit???
Old Feb 6, 2005 | 07:17 PM
ocdcivic's Avatar
Default Will this rim size fit???
Ok so I have been searching on which size rims will fit my 99 ex with h&r sports, and I am thinking of going with a 16X7 with a 40mm offset. My question is will that rub at all or should i just stick with a 15 inch rim. thanks
Old Feb 6, 2005 | 07:24 PM
eK9aT10pSi's Avatar
Default Re: Will this rim size fit??? (ocdcivic)
on my 99ex, im running agx with h&r sport with 17's for crusing. and 15 c8 for drag. you should have no problem with rubbing. on my 97 ex auto, got a sportline drop [h&r sport equivlant] with 16's with no rubbing.
ocdcivic's Avatar
Default Re: Will this rim size fit??? (eK9aT10pSi)
awesome thanks
Old Feb 6, 2005 | 07:29 PM
RzHybrid510's Avatar
If you have a big body kit on your ex, buy some 17" x 7.5". If not, buy some 16" x 7.5". Either way, the max width you can go for a civic is 7.5" I believe.
Old Feb 6, 2005 | 07:33 PM
IT'S ME DAVID's Avatar
NooB
i had 19" x 7.0" on an accord and they were startind to stick out alittle bit so i would go with 6.5" or 7" with small tires not width ones.
sasjod
Sep 10, 2007 01:04 PM
bsivoljr
Jul 11, 2007 01:16 PM
mattjars
May 14, 2005 12:51 PM
Turboteggy
Aug 3, 2004 10:57 AM
