!!!!!!!!!!!!!!!! condensor fan !!!!!!!!!!!!!!!!!!!! ???????????????????????????????
Old Feb 6, 2005 | 05:06 PM
importslife's Avatar
Default !!!!!!!!!!!!!!!! condensor fan !!!!!!!!!!!!!!!!!!!! ???????????????????????????????
can i wire in my condensor fan in with my cooling fan or can i just take it out? i have a 91 si and have gutted out my front end (a/c-comp , pipping , washer res , air box upper and lower , battery in the back. i will be taking out my condensor core from in front of the radiator. so what would be better running bouth fans or just one. if it better running bouth how can i wire it????????????????????????
Old Feb 6, 2005 | 05:07 PM
HatchBox's Avatar
Skoobie no more...
Default Re: !!!!!!!!!!!!!!!! condensor fan !!!!!!!!!!!!!!!!!!!! ??????????????????????????????? (importsli
you can take it out if you want, one fan is sufficient for cooling .
but if you want to use it as a cooling fan just splice the wires,
Old Feb 6, 2005 | 05:25 PM
but witch ones? like what color to what color?
Old Feb 6, 2005 | 05:29 PM
eda6's Avatar
Not sure about the colors. Just check rotation. If it's running backwards swap the wires.
Old Feb 6, 2005 | 05:39 PM
ok. let me ask this if i take out the condensor fan altogether, will the cooling fan run the same no rewiring?
Old Feb 6, 2005 | 05:49 PM
HatchBox's Avatar
Skoobie no more...
yes the cooling fan is on a seperate circuit then the AC fan.
Just unplug the AC fan and put it out of the way
Old Feb 6, 2005 | 05:51 PM
cool thanksl
f22a1 ftw
Aug 7, 2010 04:57 PM
Corksil
Dec 9, 2009 06:56 PM
PhantomX
Feb 16, 2009 03:04 PM
