how much power should i expect from my b16 build ?
you should gain next to nothing with just a bump in compression, the b16 cams are the least agressive of all b series vtec cams, ITR or Ctr cams would compliment you compression bump quite nicely not to mention bc III+. Personally rather than dump money into pistons why don't you either buy some cams type r's buddy clubs, rocket m20s have your head milled for 30 bucks and buy some cam gears, tune and call it a day. i wouldn t waste money of CTR pistons on a stock motor not worth the trouble at ALL
CTR pistons in a stock b16a2 motor will give some power. Mine were installed recently and I felt a bit more power in every single gear (low end & high end) including 5th gear on the freeway. It pulls slightly harder.
Next for me is skunk2 stg 1 cams.
racing_reject_001
20
May 10, 2009 04:38 AM
theslugbug
Aug 11, 2004 12:37 AM
Driven
14
Apr 4, 2004 10:58 PM
