z6 intake manifold into a cx
i have a extra z6 intake manifold laying around
what is all needed to swap it into my cx(d15b8)
i searched didnt find a direct answer on what is needed
re reads it oops i missed that what is needed part. my bad.
really dont know what is needed but i dont see why you would need a fuel pressure regulator cause the fuel/air ratio would be taken care of by the ECU and there should be enough fuel pressure to run the car anyway
yea i was woundering what that link was doing
didnt tell me what part i needed
i guess i will google it for now until someone knows
didnt tell me what part i neededi guess i will google it for now until someone knows
Might need a new FPR. CX injectors are also 180cc compared to the 240cc in the Z6 (pretty sure).
I'd use the CX FPR and injectors in the Z6 manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">what would happen if i dont get a new fpr
Your engine wont receive the correct amount of fuel, and you'll run either too rich or too lean.
you think it be worth the money to get a new fpr and gasket to gain the extra little power
im getting the shitiest gas mileage with all these hills here
eddie_jdm
do you have aim so we can talk?
eddie_jdm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">you think it be worth the money to get a new fpr and gasket to gain the extra little power
No. The reason your getting shitty gas mileage is because your car has the longest gearing known to man, and you're constantly having to floor it (in any gear) to get you anywhere.
Your best bet would be to pick up a D16Z6 or D16Y8 transmission. Those transmissions have shorter gears so you wont have to have your foot to the floor of the time to accelerate.
yea true that
one last question
the tps is broken on the z6 can i swap my cx thp to the z6?
Modified by komat at 11:41 PM 2/6/2005
one last question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">yea true that
one last question
Modified by komat at 11:41 PM 2/6/2005</TD></TR></TABLE>
tps should be the same!
one last question
wrx'n you
May 16, 2009 05:29 PM
pornstarSR
Aug 6, 2003 09:01 PM
