need a good aluminum welding shop in So Cal?
Old Feb 6, 2005 | 02:52 PM
rocketfuelcerx's Avatar
Default need a good aluminum welding shop in So Cal?
Need to have my tranny case fixed because it broke where it bolts to the mount. bolt is gonners.
Estimated cost to have an aluminum chunk welded to it, then surface, then tapped?
Old Feb 7, 2005 | 01:06 PM
Wes V's Avatar
Default Re: need a good aluminum welding shop in So Cal? (rocketfuelcerx)
You could try Valley Head Surface in Northridge. I've had them weld up an aluminum Munci case for me. Ask to speak to Larry (the owner).
They know how to do this sort of thing due to welding up damaged aluminum heads.
Wes
CompanyFlow
Transmission & Drivetrain
Apr 12, 2009 02:32 PM
boostedgsr1234
Welding / Fabrication
19
Apr 5, 2008 09:07 AM
zman
Apr 15, 2005 02:04 PM
Adam.
Sep 14, 2004 07:14 PM
the_0ne
May 21, 2004 03:07 PM
