1992 Civic hatchback, lowered on coilovers, WEIRD RUBBING NOISE??
Old Feb 6, 2005 | 11:32 AM
Ratchback's Avatar
Default 1992 Civic hatchback, lowered on coilovers, WEIRD RUBBING NOISE??
Hey there i have a 92 civic hatch with a gsr and its loweed on coilovers and i just installed Flik-Bullet rims from edgeracing.com in 15inch with falken ziex ze512 tires. I keep hearing thie weird rubbing noise so i raised the suspension and im still hearing the noise and its coming from the inner part of the fender on my front right tire so twhen i turn my wheel to the right it makes the noise. what should i do .thanks
Old Feb 6, 2005 | 12:40 PM
kine462's Avatar
Default Re: 1992 Civic hatchback, lowered on coilovers, WEIRD RUBBING NOISE?? (Ratchback)
need more description, such as which end of car noise is coming from. you could try checking your plastic sheilds.
Old Feb 6, 2005 | 07:24 PM
RzHybrid510's Avatar
Default Re: 1992 Civic hatchback, lowered on coilovers, WEIRD RUBBING NOISE?? (kine462)
Yes...need more details. Take the tire off the corner where the noise is being made and check for worn out or "shiney" areas in your wheel well and diagnose from there.
Old Feb 6, 2005 | 07:27 PM
buzzbombtom's Avatar
often times the springs make noise when the coils touch eachother, it could be that, what brand are they and some have a plate you place on them to keep the coils from rubbing eachother. dono just a thought
Old Feb 7, 2005 | 04:06 PM
Ratchback's Avatar
Default Re: 1992 Civic hatchback, lowered on coilovers, WEIRD RUBBING NOISE?? (buzzbombtom)
well it sounds like a grinding almost like brakes with no pads or a bearing or sumthin but i just got the front brake pads replace so what else could it be, the tires not rubbing on anything/
Old Feb 7, 2005 | 04:08 PM
SL!M's Avatar
Picture this, when i turn left with my drivers side tire, it scrapes, as a result i have a worn away mark on the inside of the wheel well, if you are facing the wheel well its the back right upper spot. Its due to my shocks being blown, but maybe you could have the same rubbing for one reason or another. Hope this helped somehow.
Old Feb 7, 2005 | 04:10 PM
civicboisi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ratchback &raquo;</TD></TR><TR><TD CLASS="quote">well it sounds like a grinding almost like brakes with no pads or a bearing or sumthin but i just got the front brake pads replace so what else could it be, the tires not rubbing on anything/</TD></TR></TABLE>
who put on the pads? Check them out too while you have the rim/wheel off the car. Loose parts could cause adnormal "grinding"
pityocamptes
Apr 13, 2016 03:25 PM
NightStalker
Apr 2, 2007 05:48 AM
Sic_DA_Nine
Jun 17, 2006 10:03 AM
RedHatch.eh
Mar 20, 2003 06:43 AM
