Do I need pistons for my NA H22
Old Feb 6, 2005 | 11:20 AM
tgh22a's Avatar
Default Do I need pistons for my NA H22
I just put a h22 with a skunk2 intake manifold and throttle body into my 94 accord. With my tax return and money I saved up I want to build my head with valve springs retainers stage 2 cams, P&P. So the stock motor has 10.6/1 compression. I thought about buying type s pistons but I'm not sure about what type to get. There are type A or B and over sized. I know that if I get the A or B type they just drop in, or is boring it out to .25 over worth it? Also I heard that it weakens the stock sleeves. I also thought of just leaving the bottom end alone and buying a new head gasket that could make it 11/1, would that be enough compression to make the cams preform decent?
Old Feb 7, 2005 | 03:34 PM
tgh22a's Avatar
Default Re: Do I need pistons for my NA H22 (tgh22a)
bump
Old Feb 7, 2005 | 03:59 PM
accord-25's Avatar
i would get je pistons because they hold up better
Old Feb 7, 2005 | 07:32 PM
MadnessRacing's Avatar
Default Re: Do I need pistons for my NA H22 (accord-25)
you should buy a turbo kit with the tax return!!
Old Feb 7, 2005 | 07:46 PM
chris_m's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-25 &raquo;</TD></TR><TR><TD CLASS="quote">i would get je pistons because they hold up better</TD></TR></TABLE>
you cant run forged pistons on stock h22 sleeves genius.
Old Feb 7, 2005 | 11:09 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh22a &raquo;</TD></TR><TR><TD CLASS="quote"> I also thought of just leaving the bottom end alone and buying a new head gasket that could make it 11/1?</TD></TR></TABLE>
You shouldn't be trying to make more power by using a thinner headgasket.
I would do cams and an upgraded valvetran with Hondata before I ever
messed with the block.
Old Feb 8, 2005 | 06:42 AM
Adam.'s Avatar
At MOST, you should only move up to type-s pistons and you probably won't even need them.
Old Feb 8, 2005 | 12:19 PM
chris_m's Avatar
* B A N N E D *
Default Re: Do I need pistons for my NA H22 (DarkKnight1)
he can only move up to type s pistons. You cant run forged pistons in a stock h22 sleeve thought that was pretty well known info
Old Feb 12, 2005 | 09:21 AM
accord-25's Avatar
Default Re: Do I need pistons for my NA H22 (alld16a)
that is what my h22 is on an i will burn your little b16 ***
Old Feb 12, 2005 | 10:33 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord-25 &raquo;</TD></TR><TR><TD CLASS="quote">that is what my h22 is on an i will burn your little b16 ***</TD></TR></TABLE>
you bumped this to say that
Are you trying to say your motor has been resleeved?
Old Feb 12, 2005 | 06:49 PM
NJIN BUILDR's Avatar
Default Re: Do I need pistons for my NA H22 (SKDRCR)
Yes the h22 has a composite cylinder wall that is not compliant with a forged piston.Mahle pistons make a few h22 pistons with a special skirt coating that will work with the stock cylinders,but they are a little pricey (although cheaper than sleeving).
Glenn
Old Feb 12, 2005 | 09:54 PM
SpeedingHatch's Avatar
Default Re: Do I need pistons for my NA H22 (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Yes the h22 has a composite cylinder wall that is not compliant with a forged piston.Mahle pistons make a few h22 pistons with a special skirt coating that will work with the stock cylinders,but they are a little pricey (although cheaper than sleeving).
Glenn</TD></TR></TABLE>
Links please????
As to stay on topic, type-S pistons would be okay, but not neccessarily worth the money IMO
hatchn1.9
Sep 16, 2010 04:48 PM
raysjdmh22a
Apr 1, 2006 08:59 PM
jdm knight
Feb 28, 2006 09:06 AM
lazy bum shaughn
May 3, 2003 11:31 PM
