I found an excellent 15x7 wheel deal, but the offset has me worried
I've found some lightweight 15x7s with like-new Azenis that are selling locally for a song. The only issue that makes me hesitate is I think the offset on these might be 32.
Is that going to be a problem for my CRX si with about 1.5" lowering?
32's may run rub on the inside of the rear trailing arm. I would try a test fit first, but I'm pretty sure they will rub. My 38's are close.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prkiller »</TD></TR><TR><TD CLASS="quote">32's may run rub on the inside of the rear trailing arm. I would try a test fit first, but I'm pretty sure they will rub. My 38's are close.</TD></TR></TABLE>
+32 will be much furtherout toward the fender lip of the car. My guess is that a 7" wheel with 205 Azenis--unless you have a lot of camber--are gonna rub.
Going from a 6.5 wide +40 offset to a 7.0 +32 offset should put the tires out a little more than 1/2 an inch from where they are now (given the same tire width/profile). Maybe that can give you a good eyeball estimate.
After checking with the ruler, I think there is no way I could do it without some camber correction. I'm passing on this deal. Thanks for the input!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">
+32 will be much furtherout toward the fender lip of the car. My guess is that a 7" wheel with 205 Azenis--unless you have a lot of camber--are gonna rub.</TD></TR></TABLE>
I always get that confused for some reason!
Either way, 32's or 42 wont work!
