average price for h22 swap
Really Depends what you wanna do?? do you want it to look pro?? do you wanna replace every part that you should in a swap?? I spent 1000$ CDN -or- 780$ USD just on replacement parts, and i ran into a few little problems.
I replaced, Cap & Rotor, Wires, Plugs, Ignition Coil, Radiator (Ignition & rad had to be done)
Had to get timing belt, balancer belt, auto tensioner, Cam Seals, Air Filter, Fuel Filter, Axle Seals, Valve Cover Gasket, Oil Pan Gasket, Tube Seals, mtf, oil, power steering fluid.....any we had to modify power steering hose, make a wiring harness, and modify engine mounts, and power steering brackets...........there was lots to do!
I'd say bank on 3000$ USD just to be on the safe side, i spent 3500$ USD, but i had to replace rad, and igntion coil which alone was 275, but always overestimate, and if it all goes well then you can buy an intake or header, or exhaust
goodluck, its nice after its done, if done right
Guest
Posts: n/a
If you are mechanically inclined and have the tools, get a manual and d.i.y. It's not an impossible process and if you enjoy working on your car, it's even fun. And yes, your accord tranny bolts up. This is also good if you plan on boosting. The longer gearing of the accord tranny mate well with power of the boosted H.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slim3224 »</TD></TR><TR><TD CLASS="quote">ya i got a 95 teg se and i dropped it off at shop and payed $5500 for full swap
YOU GOT F---IN RAPED
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner »</TD></TR><TR><TD CLASS="quote">YOU GOT F---IN RAPED
even with LSD 5speed, type S pistons h22, special mounts
was the car in really bad condition?
</TD></TR></TABLE>even with LSD 5speed, type S pistons h22, special mounts
TOUGHLOU--in two weeks im doin a h22 swap for someone and in return he i giving me his old motor, tranny, ecu, etc.(f22a1)...i would be willing to sell you that motor since ur looking for one
Nocturnal
11
Feb 6, 2006 10:40 AM
Jonnyr4c
14
Jan 2, 2005 07:12 AM
