High Pressure fuel line busted!!!! your feedback on this pleazzz
Old Feb 6, 2005 | 08:50 AM
EFSiR's Avatar
Default High Pressure fuel line busted!!!! your feedback on this pleazzz
ouch, my high pressure fuel line rusted to the point that it's leaking. It's right at the point of entry from the gas tank area to the inside of the car, right under the back seat of my 89 hatch.
What to do????? I don't think cutting the line right under the seat and trying to run it to the tank will work as I can't find any metric compression union adapters. I know it's close to 5/16" but with 50PSI of pressure, this union has to be precise so metric is the only way to go.
So, should I buy a brand new high pressure line from the dealer???? If that's the case, I got to take out my dash...
Old Feb 7, 2005 | 11:11 AM
EFSiR's Avatar
Default Re: High Pressure fuel line busted!!!! your feedback on this pleazzz (EFSiR)
Old Feb 7, 2005 | 11:20 AM
phatrick2332's Avatar
buddy of mines car did the same. we just cut it and then put a rubber fuel line over top of the steel line and hosed clamped it. I dont recommend it as a permanent fix, but it will be ok for a while. I believe hes still driving around that way after about 7 months.
Old Feb 7, 2005 | 11:54 AM
EFSiR's Avatar
Default Re: (phatrick2332)
the problem is that this is a 48PSI of fuel. will rubber and few clamps hold??
Old Feb 7, 2005 | 12:09 PM
ssl2k's Avatar
Default Re: (EFSiR)
just regular fuel line 5/16" is usually rated at 300psi.
I use it for my oil lines (turbo) and that pushes lke 70ish psi
Old Feb 7, 2005 | 01:18 PM
yea, 50 psi isnt ****
97mm_EH3
Apr 12, 2011 05:31 AM
Marcg611
Aug 10, 2010 05:24 PM
damn_import_culture
Aug 27, 2009 04:56 PM
Louie_EM1
12
Feb 27, 2005 11:16 AM
