Replacing Rear Brakes on 2003 Accord
I'm changing the rear brakes on my 2003 Accord EX, but I can't seem to retract the piston, even with a c-clamp, so I can fit the new pads. I can see the hand brake line but don;t know how to remove it. Is this why I can't retract the piston?
on the rear brakes, i believe you need to turn the piston counterclock to push it back. at autozone you may find a special tool to help you with that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frankie324 »</TD></TR><TR><TD CLASS="quote">on the rear brakes, i believe you need to turn the piston counterclock to push it back.</TD></TR></TABLE>
You mean clockwise, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sportsguy »</TD></TR><TR><TD CLASS="quote">... even with a c-clamp...</TD></TR></TABLE>If you've already cranked on it with a C-clamp, it's possible you damaged it so now it won't retract when you twist it. (clockwise...)
sting94112
Dec 5, 2003 02:45 PM
