1992 Accord fuel relay
Old Feb 6, 2005 | 07:20 AM
Shevy's Avatar
Default 1992 Accord fuel relay
I have a 92 Honda Accord. After driving for even a few minutes, sometimes it won't start for 10 to 20 minutes. Sometimes several hours. It will also loose power while going down the road and die. The engine still revs and you can downshift, but it will die once the speed gets below like 10mph. If it is the fuel relay, where can I find it on the car and how do I check it?
Old Feb 6, 2005 | 08:29 AM
92acc's Avatar
Default Re: 1992 Accord fuel relay (Shevy)
it is under the drivers side dash, it is a little black box about 1 by 2 inches and it is bolted to the under side of the dash, vertical to the brake pedal, one connector. very easy to change, me being a small guy it was easier to get to. imagine siiting in the seat upside down with your but in the back of the seat and your back in the floor and look straight up under the dash that is where it is.
Old Feb 6, 2005 | 12:36 PM
TxTuner
Guest
Posts: n/a
As far as the car dying while your rolling, it's more than likely your idle. Take it to a shop and have it adjusted
Old Feb 8, 2005 | 10:56 AM
Shevy's Avatar
Default Re: 1992 Accord fuel relay (92acc)
Thanks. I'm going to give it a shot and hope that it solves the problem. If not I'll get the altinater tested and go from there. Thanks again.
Old Feb 8, 2005 | 11:00 AM
Shevy's Avatar
Default Re: 1992 Accord fuel relay (TxTuner)
Just courious, if the car idles fine when idling, how would that effect it driving. Or when it's trying to start?
ElMay1mb312
Classic Hondas
10
Feb 29, 2012 07:40 PM
lifedeuce
Apr 6, 2011 07:39 AM
STEVENPAULGRUNDEY
Jul 1, 2007 10:39 AM
jsteezy1290
Sep 24, 2004 08:03 AM
zmeli
Oct 1, 2003 01:11 PM
