put in tech but no answer (did a search)
Old Feb 6, 2005 | 12:12 AM
cutt's Avatar
Default put in tech but no answer (did a search)
I have a 1990 civic si I just swapped the motor to a built d16z6 with a frog wirring harrness then had a turbo installed right a way so I have never been able to hear the vtec kick in, cause of all the other noise, and i have no codes. I am getting on a dyno in the next couple of weeks to tune my E manage so I want to make sure everything is working fine before doing the timing and fuel adjustments.
everything was cleaned before putting the motor back to gether and my oil presure is correct. just not sure about the solinoid itself and the wirring.
Old Feb 6, 2005 | 12:25 AM
CRX_1.8T's Avatar
Default Re: put in tech but no answer (cutt)
What is your question? Did you want to know what VTEC sounds like, or if yours is wired correctly?
luded as fuhh
Dec 1, 2010 02:44 PM
Fighterinsnatch
52
Apr 10, 2007 06:43 PM
Dr.Evil
12
Sep 15, 2004 01:46 PM
JDM-EJ1
11
Jan 30, 2004 09:44 PM
