will 95 block match a 97 head and tranny????????
Old Feb 5, 2005 | 09:38 PM
DEL HATCH's Avatar
Default will 95 block match a 97 head and tranny????????
im looking to buy a sleeved block but it is a 95 h22a1 and i own a 1997 prelude that has a h22a4 i need to know if my head will match that block. both of the motors are base model preludes, not type s. i also need to know if a 97 crank will work in a 95 block.. thanks
Old Feb 5, 2005 | 09:51 PM
The Phil's Avatar
Default Re: will 95 block match a 97 head and tranny???????? (1fast5gen)
base model 95 preludes had F22s in them, not h22s.
and if i remember right, all the stuff within the H series should be interchangeable, so all of what you're saying should work fine
Old Feb 5, 2005 | 09:55 PM
Shakes's Avatar
space cadet
Default Re: will 95 block match a 97 head and tranny???????? (xthephilx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">base model 95 preludes had F22s in them, not h22s.
and if i remember right, all the stuff within the H series should be interchangeable, so all of what you're saying should work fine</TD></TR></TABLE>
wrong. if you dont know, dont post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1fast5gen &raquo;</TD></TR><TR><TD CLASS="quote">im looking to buy a sleeved block but it is a 95 h22a1 and i own a 1997 prelude that has a h22a4 i need to know if my head will match that block. both of the motors are base model preludes, not type s. i also need to know if a 97 crank will work in a 95 block.. thanks</TD></TR></TABLE>
the 95 block will have to be made OBD II. crank position sensor is one thing i know for sure. do some research for the rest. but other then that yes the head will fit and work as long as it is an H22 block and head.
the 97 crank is the cutoff for the 50mm mains. so that will work. 98+ however will not.
all-mtr-teg
Nov 19, 2007 02:41 PM
hybridracer504
Oct 18, 2006 08:46 AM
philafelman
Sep 18, 2003 10:12 PM
Conechaser
May 25, 2003 06:36 PM
groovinmind
Nov 30, 2002 12:38 PM
