Fidanza or Act pro lite flywheel?
Old Feb 5, 2005 | 08:45 PM
ajmj's Avatar
Default Fidanza or Act pro lite flywheel?
I am going to purchase a flywheel and want a 8lb one. Just wondering what set up would be a better flywheel. I have an ACT street clutch. Thanks for your help.
Old Feb 5, 2005 | 09:23 PM
PrettyLude's Avatar
fidanza it has the replaceable face on it
Old Feb 6, 2005 | 10:37 AM
ajmj's Avatar
Default Re: Fidanza or Act pro lite flywheel? (ajmj)
thanks, anyone else
Old Feb 6, 2005 | 05:02 PM
street_ruler's Avatar
act...teh repolaceable face is a shitty thing
where the weight comes off matters more than the physical amount of lbs...you want weight removed form the outside, where act removes it...
plus fidanza is aluminum...not a great material to make somthig that needs to be strong, and you cant ever resurface em
Old Feb 6, 2005 | 06:48 PM
chandler's Avatar
you dont need to resurface them, thats where the replacable friction surface comes in, as for the strength problem, aluminum is fine, if your really worried about it, get a cromoly flywheel
Old Feb 6, 2005 | 07:48 PM
Default Re: (chandler)
no **** you cant resurface em, thats my point, its about 90 bucks for a new surface, and only about 25 to resurface...make sense?
Old Feb 6, 2005 | 07:59 PM
v4lu3s's Avatar
RTFM
Competition Clutches flywheel
Old Feb 6, 2005 | 08:05 PM
2point6's Avatar
Default Re: (street_ruler)
I hate ignorance. Yes, they can be resurfaced. Call the manufacturer... I just had 2 done. $30 each locally.
Old Feb 6, 2005 | 08:08 PM
Default Re: (2point6)
aluminum ones...they cant...the steel ones you can
Old Feb 6, 2005 | 08:17 PM
2point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ruler &raquo;</TD></TR><TR><TD CLASS="quote">aluminum ones...they cant...the steel ones you can</TD></TR></TABLE>
Sorry, man just had 2 done. Yes, they are aluminum. Yes, it can be done.
Old Feb 6, 2005 | 09:08 PM
are you sure tehy wernt steel faced inserts with the aluminum bodies??? cause fidanza does make those too
Old Feb 6, 2005 | 09:29 PM
stubk20's Avatar
fidanza had mine for 8 months and no complaints
Old Feb 7, 2005 | 06:37 AM
PrettyLude's Avatar
you can resurface the aluminum ones, but i would rather buy a new face
Old Feb 7, 2005 | 02:26 PM
2point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ruler &raquo;</TD></TR><TR><TD CLASS="quote">are you sure tehy wernt steel faced inserts with the aluminum bodies??? cause fidanza does make those too</TD></TR></TABLE>
Dude, every aluminum flywheel has a steel insert. I am pretty sure I can distinguish between aluminum and steel to start with, but thanks for your concern.
Old Feb 7, 2005 | 03:16 PM
not all of em man, some are aluminum inserts
Old Feb 7, 2005 | 03:25 PM
ajmj's Avatar
thanks everyone didnt mean to start an argument
Old Feb 7, 2005 | 03:41 PM
chandler's Avatar
on my 240 I have a Fidanza flywheel with a steel insert, the insert was chewed as hell when I got it ( got it for free) so I got a new insert for 50$, I would assume if the friction surface isnt messed up badly you can resurface it, but if it was like mine, which was abused with a 6 puck solid hub, you need a new surface, my .02$
Old Feb 7, 2005 | 03:52 PM
2point6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ruler &raquo;</TD></TR><TR><TD CLASS="quote">not all of em man, some are aluminum inserts</TD></TR></TABLE>
Whith respect, please show me an all aluminum flywheel for a honda without a steel insert.
Old Feb 8, 2005 | 11:39 PM
silversurfer2282's Avatar
Got my fidanza with organic and it's been so fun to drive. No problems, and I know Fidanza wasn't the best a couple of years, but they are better now.
Old Feb 9, 2005 | 06:45 AM
VisPreludeVtec's Avatar
Default Re: (silversurfer2282)
I like my ACT pro-lite, easy driveabilty and fast revving
Old Feb 9, 2005 | 11:46 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (VisPreludeVtec)
Yeah but which is better?? Is it just a matter of choice??
Old Feb 9, 2005 | 11:57 AM
Default Re: (cb7-R)
i think it is what you want pretty much. I have heard good about both. I went with the ACT because i have the ACT clutch
Old Feb 9, 2005 | 11:59 AM
mgags7's Avatar
until someone puts a dyno on here all this worthless babbling is.....worthless.....
and YES you can resurface the fidanza, which has a STEEL insert, and NO there is no flywheel with an aluminum friction surface.....
tekstyle
Dec 16, 2007 06:48 AM
fled
Jul 5, 2006 12:06 PM
b16a27
Nov 5, 2004 04:43 PM
Rocks
Aug 23, 2004 12:27 PM
97F22B2
Sep 23, 2003 12:25 AM
