Transmission makes this squel noise
Old Feb 5, 2005 | 08:30 PM
Tronix102's Avatar
Default Transmission makes this squel noise
When stepping on the gas normally it doesnt do it but if you step on it a little more, giving it more power the tranny makes this weird *** squel noise. I am pretty sure its the tranny because its coming from the right side so its not the belts or anything... anyone know what this could be?
Old Feb 7, 2005 | 12:26 PM
LowTec MOHawk's Avatar
Default Re: Transmission makes this squel noise (Tronix102)
what kind of car/transmission do you have? is it automatic or manual? well if its and automatic there is something called a CVT (contiuously variable transmission) this kind of transmission uses a set of pulleys and an extremely tough rubber belt with metal threadings or a chain belt (like the timing chains on old ford and chevey v8's) if the belt starts to slip and get old then it could possibly make a squeal like you say but i dont know how likely it is that you have that kind of trans. on regular transmissions id think that the trans wasnt the prob. get more details on your car info and ill try to help you more.
Old Feb 7, 2005 | 12:54 PM
Knightsport's Avatar
El Chico
25 Year Member
Community Builder
Community Influencer
Default Re: Transmission makes this squel noise (mikeformos03dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeformos03dx &raquo;</TD></TR><TR><TD CLASS="quote"> get more details on your car info and ill try to help you more. </TD></TR></TABLE>
Agreed, otherwise there are millions of possibilities.
Old Feb 7, 2005 | 05:11 PM
Tronix102's Avatar
1993 Prelude Si with a h22a 5 speed. Sorry about that heh.
Old Feb 7, 2005 | 06:24 PM
hOndafienD 04's Avatar
what clutch?
Old Feb 8, 2005 | 12:18 PM
Tronix102's Avatar
ACT ha3-hdss
Old Feb 9, 2005 | 01:21 PM
Tronix102's Avatar
anyone?
Old Feb 9, 2005 | 03:19 PM
Under_Pressure's Avatar
Default Re: (Tronix102)
I have this same noise on my m2s4 tranny. On every shift it makes a squel noise that last about a sec. I have a dual friction clutch.
Old Feb 11, 2005 | 08:02 AM
Tronix102's Avatar
bump
Old Feb 11, 2005 | 09:44 AM
BlackBird_SC61's Avatar
It happened to me after i put in my clutch and fly wheel. I think its just the friction between the disc and the flywheel. If you time it right you can avoid the sound. Nothing bad has happened, heard its normal if you have bronze pucks on the clutch. if its an organic disc it may be a different problem.
micah_m
Jul 26, 2013 09:09 AM
myhondatechacct
Jul 21, 2011 08:57 PM
VTEC-LUDE
Jun 1, 2006 05:14 AM
User 5426
Aug 22, 2004 11:10 PM
