HKS Manifold/GT3071R-WG/GT-elbow
Old Feb 5, 2005 | 07:14 PM
edo's Avatar
edo
Default HKS Manifold/GT3071R-WG/GT-elbow
These are pics of the HKS RSX-S cast turbo manifold with a Garrett GT3071R-WG .86 AR and aftermarket SR20DET GT-style 5-bolt flanged, divorced turbo elbow/O2 extension.
Don't mind the little dings on the compressor housing, the cover can be replaced without affecting the center section balance.
Look how it was packed:
It should've been centered better, you can see where the housing broke the cardboard while it shifted in transit or warehousing.
-Ron
Old Feb 6, 2005 | 02:32 PM
MooFX's Avatar
Beautiful!
Old Feb 6, 2005 | 10:00 PM
edo's Avatar
edo
Default Re: (MooFX)
The elbow almost works, but you know what they say... no cigar. The 3-bolt flange is too close to the inner CV joint. We're going to rework the piece, or just build one from scratch with this flange:
The 4" compressor inlet is going to be tricky, but we'll get an intake on it. If the CN manifold placement is close to where the HKS places this one, we may be able to get something that fits both applications.
-Ron
Old Feb 6, 2005 | 10:22 PM
mrdanglez's Avatar
Default Re: HKS Manifold/GT3071R-WG/GT-elbow (edo)
i wanna see sum numbers!
Old Feb 6, 2005 | 10:24 PM
k20z's Avatar
* B A N N E D *
stock motor?
Old Feb 6, 2005 | 10:25 PM
Scr4ppY's Avatar
Bad ***. Be sure to post a video of the dyno. Good luck with install!
Old Feb 6, 2005 | 10:58 PM
edo's Avatar
edo
Default Re: (ROFL COPTER)
We're starting with an internally stock RSX-S, so boost levels will be kept to moderate levels isolating the turbo kit for a good indication as to how it stacks against others on the market. After that, we're going to upgrade to 3bar map, fuel pump and injectors along the way while testing various cams: stock, ITR and aftermarket.
That's the plan anyway. I'm sure we'll be seeing some curveballs shortly.
-Ron
Old Feb 6, 2005 | 11:00 PM
edo's Avatar
edo
Default Greddy IC kit fitment
Work in progress.
-Ron
Old Feb 7, 2005 | 01:20 AM
Moogen Powah's Avatar
Default Re: Greddy IC kit fitment (edo)
Nice work so far
Old Feb 7, 2005 | 06:07 AM
EFDawg's Avatar
Default Re: Greddy IC kit fitment (Moogen Powah)
Hell yes, Ron, that looks badass.
BTW, I see the liquid enthusiasm in the background on that last pic.
Old Feb 7, 2005 | 06:58 AM
Halo's Avatar
Default Re: Greddy IC kit fitment (DC5Dawg)
drool
Old Feb 7, 2005 | 11:50 AM
Archidictus's Avatar
Unceasing Measure
So how does the wastegate setup work on that? Nothing external that I can see, but no vacuum/rod actuator outside the snail either.
Never seen one like that. Anbody wanna fill me in?
Old Feb 7, 2005 | 12:04 PM
EFDawg's Avatar
Default Re: (Archidictus)
Ron told me on a separate occasion that this was an internally wastegated turbo (hence the WG in the name). I am sure he just has the acuator off right now.
Old Feb 7, 2005 | 12:13 PM
edo's Avatar
edo
Default Re: (DC5Dawg)
Yep, internally gated - actuator not installed in those pics.
-Ron
Old Feb 7, 2005 | 07:41 PM
B18CXr's Avatar
Default Re: (edo)
Old Feb 8, 2005 | 12:57 PM
PrettyLude's Avatar
I posted on clubrsx. But that dent is really annoying. I can see why you'd want another one. I can't wait to see the dyno. I'm hoping for a nice torque curve.
Old Feb 8, 2005 | 10:42 PM
edo's Avatar
edo
Default Oil filter relocation & turbo coolant lines
-Ron
Old Feb 8, 2005 | 10:44 PM
edo's Avatar
edo
Default T-clamps and turbo discharge routing
That's all for now.
-Ron
Old Feb 9, 2005 | 03:57 AM
EFDawg's Avatar
Default Re: Oil filter relocation & turbo coolant lines (edo)
Ron,
Email me with the info on those filter relocation parts.
Old Feb 9, 2005 | 01:52 PM
Davanca's Avatar
Default Re: Oil filter relocation & turbo coolant lines (DC5Dawg)
Im just curious where does the wastegate go?
Old Feb 9, 2005 | 02:12 PM
edo's Avatar
edo
Default Re: Oil filter relocation & turbo coolant lines (Kaiba Corp. W)
It's internally wastegated, built into the exhaust housing. A flapper door bleeds off excess boost with an actuator and will be controlled by a dual solenoid Blitz SBC id III.
-Ron
Old Feb 9, 2005 | 02:22 PM
lube's Avatar
Lookin' good Ron
Old Feb 9, 2005 | 09:27 PM
edo's Avatar
edo
Default Re: Oil filter relocation & turbo coolant lines (lube)
Turbo coolant lines connected.
-Ron
Old Feb 9, 2005 | 09:28 PM
edo's Avatar
edo
Default Last leg of IC piping
Since we didn't start out with the complete Greddy turbo kit, we needed to fab the missing IC segment that couples with the throttle body.
IC plumbing is now complete.
-Ron
Old Feb 9, 2005 | 09:49 PM
Scr4ppY's Avatar
Wow GG, what else needs to be done before your set up is complete?
