Length and fitment on Civic Type-R's sideskirt
Hi, i would like to know the length and the fitment on the CTR sideskirt, i want to see if i can fit it on my Integra. I really liked the CTR's side's design.
The EP3 CTR sideskirts are glued and fixed to the chassis with screws at both ends.
I don´t know the exact length but I could measure it for you tomorrow.
I dont know if they are the same length but even if they were I dont think the sideskirts would sit flush against the Integras body, I am sure the lines on the car are not the same. Would look good tho.
The real CTR side skirt is not glued on. There are clips on the insider of the kit, therefore you can drill hole and attach the clicks. Most people however don't like to drill hole into the side of there car so they took out the clicks and put double sided tapeon the place where the clips were and stick that to the body. Also... the rear end of the side skirt are opened end therefore you canno screw it into the read wheel weld. THe front however you can do it.
The replica such as the VIS, there is no clip on the inside of the side skirts there for you will need lot of double sided tape. Another different is that on the rear end of the sideskirt it is close like the front end so therefor you can screw it in from the rear fender weld as well as the front.
Hope that help.
Hope that help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ep3boy »</TD></TR><TR><TD CLASS="quote">6 1/2 feet.</TD></TR></TABLE>
just pulled mine out of my closet for you. just over 72"[6ft.]
George Knighton
117
Feb 15, 2006 11:19 PM
R2D2
Jun 1, 2002 02:37 PM
