Rear disc conversion on a 88-91
Old Feb 5, 2005 | 05:40 PM
puffsef's Avatar
Default Rear disc conversion on a 88-91
I just put my rear disc on my 88 hatchback dx model and I am not getting pressure. We bled the lines in the right order and got all the air out but for some reason there is just no pressure. I read somewhere that it is recommended that you use the proportioning valve off of an integra to get the full preformance. I got tired of it and put it all back together and took it down the street and it works fine and like it did before. I am not having problems with it stopping so?????????
But my main question is since I am using the stock proportioning pieces could that not be sending enough pressure through the line because it is made to usually run a drum or whats up. Any answers is great.
Thanks
Old Feb 5, 2005 | 06:14 PM
EJ2-Fluffy's Avatar
Default Re: Rear disc conversion on a 88-91 (puffsef)
You need the CRX SI or 4040 Integrta Proportioning valve or else it wont send enough pressure to the back brakes
Old Feb 5, 2005 | 08:32 PM
BOSS-REX's Avatar
Default Re: Rear disc conversion on a 88-91 (CRX-Fluffy)
88 CRX with 90-93 teg rear disc, I didn't change the proportioning valve and it stops better than the drums.
Old Feb 5, 2005 | 10:26 PM
puffsef's Avatar
Thanks for the input. Thats what I thought to about the proportioning valve. Like I said before I drove it around and it seems to do fine but as far as the preformance side goes it is a little better than what I had before with just the front but I am sure once I get that valve in place I will be noticing a huge difference.
Thanks again for all your help.
Ebrake650
Jan 14, 2008 12:18 PM
ROTEN EF8
May 8, 2007 06:35 PM
pac_crx
Jul 15, 2006 05:53 PM
highflyinhonda
Sep 3, 2005 08:51 AM
EL Vap133
47
Dec 19, 2003 08:27 AM
