vtec firing on and off??
Old Feb 5, 2005 | 05:22 PM
KtotheEK's Avatar
Default vtec firing on and off??
I have a stock b16 and my ecu is throwing a code for iatc sensor, i cleaned my sensor and the problem is still there. Somehow i dont think the sensor is the source of my problems, maybe distributor! Any suggestions would be much appreciated.
Old Feb 5, 2005 | 05:32 PM
Stoich EG2's Avatar
Default Re: vtec firing on and off?? (retarded)
it was throwing a code for iatc sensor and you cleaned it. did you check the CEL code if it was still there? if it's still there, cleaning probably didn't solve anything. check wiring to it or the sensor is probably busted.
Old Feb 5, 2005 | 05:35 PM
Stoich EG2's Avatar
Default Re: vtec firing on and off?? (Advan06)
maybe this will help too.
https://honda-tech.com/zerothread?id=830163
Old Feb 6, 2005 | 12:34 AM
KtotheEK's Avatar
thank you, link to the info was very helpful....you rawk!!!
leonardsmith
Honda CR-V & Element
Dec 1, 2021 06:33 PM
hondaaccordf23
Oct 25, 2012 03:54 PM
N1NjA TuRtLE
12
Jun 5, 2004 08:30 PM
