Factory matched Paint
Anyone know where to find factory matched spray paints at? I know duplicolor and other companys make them, but I cant locate any in my paint code. B-97M which is 2001 Integra Voltage Blue. Any help would be great.
Jai
Jai
http://paintscratch.com/ Haven't used them myself, but have seen positive things about them on H-T.
So with them it turns out to be a perfect match then? I have heard that the Voltage blue is a really hard color to match, any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INTEGRAJAI »</TD></TR><TR><TD CLASS="quote">So with them it turns out to be a perfect match then? I have heard that the Voltage blue is a really hard color to match, any ideas?</TD></TR></TABLE>
I don't have any problems with them either. my color firepepper red pearl metallic is a hard color to match perfectly but when I ordered from them.......volia! perfect match. besides if they don't match it up the first time, they'll redo it for you free of charge can't beat that!
So I assume since their page says my car REQUIRES a basecoat and a clearcoat, I HAVE TO order both? Any clues if I HAVE TO order their specific primer as well?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by INTEGRAJAI »</TD></TR><TR><TD CLASS="quote">So I assume since their page says my car REQUIRES a basecoat and a clearcoat, I HAVE TO order both? Any clues if I HAVE TO order their specific primer as well?</TD></TR></TABLE>
You only have to buy the primer IF your paint is chipped to the point bare metal is showing then you need the primer. for the basecoat and clearcoat, I HIGHLY recommend using both because if you only use the basecoat you will get that cheapass 1-Day Paint/ Macco semi shine/dull look on your paint. The majority of modern cars nowadays uses a minimum of 2-stage paint: basecoat and clearcoat. The clearcoat is what gives it the shine.
BTW click in the icons on that specific website and it will tell you exactly the same thing I just told you.
HATCHBACK GORILLA!
Feb 25, 2008 06:33 PM
phatrick2332
May 2, 2005 07:42 AM
