b16a2 dyno results
Old Feb 5, 2005 | 04:40 PM
athoughts's Avatar
Default b16a2 dyno results
Fellas
Just got back from getting my car dyno tuned by Aries over at aebs on Miramar rd..
numbers seemed kinda low for my tasting but ill be there eventually,
Dont have the time right now to scan out the dyno sheet but here are the numbers
Max power - 164.3 Max Torque - 107.6
b16a2
p&p head
3 angle valve job
Stage 2 Gude cams
AEM cam gears/pullys
AEM fuel rail
B&M fpr
Bullfrog TB 62mm
aebs intake manifold
AEM cia
HKS cat back
4-1 header
Modified by athoughts at 5:56 PM 2/5/2005
Old Feb 5, 2005 | 04:53 PM
hybrid_vtec's Avatar
Default Re: b16a2 dyno results (athoughts)
I went up to AEBS today and took a peek, not bad! Hopefully you will get some better cams and bump up the compression. Then we will see what she can push out!
Modified by hybrid_vtec at 7:15 PM 2/5/2005
Old Feb 5, 2005 | 05:10 PM
UncleD's Avatar
Default Re: b16a2 dyno results (hybrid_vtec)
He did spell it "gude," the torque numbers seem way low to me.....
Old Feb 5, 2005 | 05:14 PM
athoughts's Avatar
Default Re: b16a2 dyno results (clean rice)
yeah i edited it :D
Old Feb 5, 2005 | 06:08 PM
erebunicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">He did spell it "gude," the torque numbers seem way low to me.....</TD></TR></TABLE>
its a b16, lol. my friend had i/h/e and got 100.3 tq on a sir2.
Old Feb 7, 2005 | 01:09 PM
supertran25's Avatar
Default Re: b16a2 dyno results (erebunicrx)
hp is nice, torque seems low. With more tunning you can squeeze out more torque.
Old Feb 7, 2005 | 01:29 PM
RobbieG35's Avatar
12 Years Strong
Default Re: b16a2 dyno results (supertran25)
What did you tune with - VAFC, Hondata, etc.?
Old Feb 7, 2005 | 01:51 PM
rodrez.'s Avatar
On your other thread, you didn't mention what ECU you were using with the VAFC.
Old Feb 7, 2005 | 03:13 PM
athoughts's Avatar
Default Re: b16a2 dyno results (MF rodrez.)
Stock ECU
Just wanted to see where i was at
Old Feb 7, 2005 | 03:17 PM
Mag00n's Avatar
You gained almost 20whp tuning. I would pretty happy about that.
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">Stock ECU
Just wanted to see where i was at</TD></TR></TABLE>
There's where your torque went.
Old Feb 7, 2005 | 03:26 PM
athoughts's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mag00n &raquo;</TD></TR><TR><TD CLASS="quote">You gained almost 20whp tuning. I would pretty happy about that.</TD></TR></TABLE>
Yeah im way happy about that, it feels nice - thanks Aries
Just waiting till my tax returns to do the bottom end :D
then hopefully spit out some nice numbers
I just thought the numbers would come out a little higher
Old Feb 7, 2005 | 04:40 PM
athoughts's Avatar
How much more power can be pulled out of a difference ECU?
Old Feb 7, 2005 | 04:42 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">How much more power can be pulled out of a difference ECU? </TD></TR></TABLE>
Was it a factory P28 or B16 small box ECU?
Old Feb 7, 2005 | 05:15 PM
athoughts's Avatar
whatever the 00' b16a2 is
Old Feb 7, 2005 | 05:23 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">whatever the 00' b16a2 is</TD></TR></TABLE>
Hmmm, your car is a 92-95 coupe, and I imagine it's still OBD1 correct? If so, probably the P28.
Old Feb 7, 2005 | 08:34 PM
athoughts's Avatar
Most likly -
Ive been thinking...
My base line run was 148whp and 99tq...
with -
p&p head
3 angle valve job
Stage 2 Gude cams
AEM fuel rail
B&M fpr
Bullfrog TB 62mm
AEM cia
HKS cat back
4-1 header
Thats way to much money invested for like 15hp gain off of a stock b16a2
something wrong?
Problems: ???
1. compression ... but it hasnt been that long since its been built so i dout it
2. stock ecu
Link to the other thread - https://honda-tech.com/zerothread?id=1139732
Old Feb 7, 2005 | 08:47 PM
jlacoy82's Avatar
71.192.16.183
This post makes me feel alot better about building my d-series. Sorry, but it does.
Old Feb 7, 2005 | 08:50 PM
builthatch's Avatar
MiG-21 superfan
Default Re: b16a2 dyno results (jlacoy82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlacoy82 &raquo;</TD></TR><TR><TD CLASS="quote">This post makes me feel alot better about building my d-series. Sorry, but it does.</TD></TR></TABLE>
that is what i like to hear lol
to 'athoughts', a true standalone like the PowerFC will benefit you greatly...
Aries is one of the best in the biz tho, no doubt....
Modified by builthatch at 10:32 AM 2/8/2005
Old Feb 7, 2005 | 10:12 PM
rodrez.'s Avatar
Problems: ???
2. stock ecu
Link to the other thread - https://honda-tech.com/zerothread?id=1139732</TD></TR></TABLE>
ECU is very important. I'd look to upgrading that with a new program, or something like Hondata.
That's cool. Looking at 97% of dyno's with DOHC motors makes me feel better about dumping the D series.
Old Feb 7, 2005 | 10:23 PM
civic2slo's Avatar
[/url]</TD></TR></TABLE>
Thats kinda of low for all the work you have done. do you have a catalytic converter? if you do check to see if its clogging up...Is it the stock pr3 or p30 pistons? You compression might toolow for your cams. as I said in the other post have you check the little things...filter/plugs/wires/ect. Also what ecu program are you using?
Old Feb 8, 2005 | 12:37 AM
rodrez.'s Avatar
Default Re: b16a2 dyno results (civic2slo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2slo &raquo;</TD></TR><TR><TD CLASS="quote">
Thats kinda of low for all the work you have done. do you have a catalytic converter? if you do check to see if its clogging up...Is it the stock pr3 or p30 pistons? You compression might toolow for your cams. as I said in the other post have you check the little things...filter/plugs/wires/ect. Also what ecu program are you using?</TD></TR></TABLE>
Did you read any of this thread?
Old Feb 8, 2005 | 04:34 AM
civic2slo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MF rodrez. &raquo;</TD></TR><TR><TD CLASS="quote">
Did you read any of this thread? </TD></TR></TABLE>
Yeah I did but I was also refering to the other posts he also had. The ones with the dyno sheets in which it seems that there were two different ecus used...
Old Feb 8, 2005 | 06:28 AM
stevel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts &raquo;</TD></TR><TR><TD CLASS="quote">Fellas
b16a2
p&p head
3 angle valve job
Stage 2 Gude cams
AEM fuel rail
B&M fpr
Bullfrog TB 62mm
AEM cia
HKS cat back
4-1 header
Modified by athoughts at 5:56 PM 2/5/2005</TD></TR></TABLE>
ouch. something seems wrong there. Just for comparison's sake I dyno'd 165/116 on my b16a2. It only had skunk2 stage 1 cams, portflow/itr valvetrain, ctr pistons, jdm 4-1, Apexi WS exhaust. The head wasn't milled or ported, stock b16 IM and TB.
s
Old Feb 8, 2005 | 12:18 PM
athoughts's Avatar
Default Re: b16a2 dyno results (stevel)
yes something is wrong.
