88 DX tranny HELP!
yes you can, however, you may have to use the DX differential carrier and bearings and swap the Si ring gear onto it - not all cases are compatible as far as bearing sizes
Okay, well would swapping the mainshaft out of an 88 Si be as easy as changing the mainshaft? I have a spare 88 Si trans I had forgot about. And I have the old 89 Si mainshaft. - Darrell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx »</TD></TR><TR><TD CLASS="quote">yes, you can swap mainshafts - you are wanting to put the 89 mainshaft in the 88 because of clutch - correct?</TD></TR></TABLE>
Yes wo0t just what I wanted to hear. Thanks for the replies jli, you rock. - Darrell
xXx Justin xXx
Jun 7, 2002 02:55 PM
