Adjusting the shifter
Old Jan 15, 2002 | 06:21 PM
Batoutahell's Avatar
Default Adjusting the shifter
I'm starting to think that the forward/backward pitch of our shifter can be adjusted by manipulating the shift rod and extension rod. My shift **** has always been too far forward for my taste - it feels like I'm reaching for my cigarette lighter when I grab 5th gear. I wonder if I adjust the positioning of the extension rod where it connects behind the tranny, can I change how far forward/back my shift **** sits? If it is adjustable, does anyone have instructions on how to do it?
Old Jan 15, 2002 | 07:12 PM
Nebulaz's Avatar
New User
Default Re: Adjusting the shifter (Batoutahell)
Try adjusting your cross over cables and decrease the throw size of 5th gear. worked on my neon.,
Old Jan 15, 2002 | 07:15 PM
sgT's Avatar
sgT
B&M makes one. but since its made of metal rather than rubber, the vibrations
eventually cause the stabilizer bar to crack at the welds.
Old Jan 15, 2002 | 07:18 PM
MrBite's Avatar
Default Re: Adjusting the shifter (Nebulaz)
Integras dont' have cables, it's a solid linkage. That means that in order to bring the shifter closer to you (which I would like to do as well) you need to shorten one of the linkages. This should be doable, but probably tough, and it might be fragile if you have to cut and weld...hmm...
Old Jan 15, 2002 | 07:24 PM
Eric R's Avatar
Default Re: Adjusting the shifter (sgT)
Cables in our car???
Being the ITR stock, I don't think there is adjustment for the shifter.
Old Jan 15, 2002 | 07:26 PM
I seem to recall that the rubber connector on the tranny side of the shift extension bar spins freely. The bolt hole that is cut into the rubber insert is off-center. By rotating that rubber insert, can I change the position of the shift linkage (front to back), and thereby move the shift **** forward or backward?
sgT's Avatar
sgT
it is not off center.
Old Jan 15, 2002 | 07:39 PM
kkim's Avatar
was the shifter ever out of the car for any reason or a short shifter installed? the shifter may be installed backwards. it's happened before. I just purchased my 98 R and the DC shifter was installed backwards. turned it around and it felt like a totally different car! better yet... I've now reinstalled the stock shifter and am very happy with the smooth slick shifter as compared to the notchy DC.
Old Jan 15, 2002 | 07:44 PM
After Budman finished his clutch replacement tonight, we noticed that his shift **** now sits MUCH further forward than before. His neutral now sits pretty close to where his first gear used to engage. We used to kid around that my shift **** sat further forward than his, and I had to reach forward to grab 3rd and 5th gears. Now, after re-installing his tranny, his shift **** sits further forward than mine...it moved alot. I was guessing that whatever we did to cause this change could be reversed (if we only realize what we did ). Any ideas? I'd like to move my shift **** back a bit for a more comfortable reach.
Old Jan 15, 2002 | 07:49 PM
sgT's Avatar
sgT
Did you remove the shift linkage from the shifter??
Ive seen it installed backwards before, and i must say i was laughing for days.
Old Jan 15, 2002 | 08:19 PM
We removed the shift lever from the transaxle (removed the spring clip and punched out the cotter pin). Hypothetically speaking, just how easy is it to mistakenly install the shift rod to the transaxle upside down? Hypothetically speaking, that is.
Old Jan 15, 2002 | 08:20 PM
sgT's Avatar
sgT
pretty hard considering you cant.
Old Jan 17, 2002 | 04:16 AM
BudMan's Avatar
Alrighty boys - Batoutahell & I aren't completely nutz!!! I knew that the previous owner of my R told me he tried 2 different shortened shifters, but neither worked well so he sent them back. What I didn't know was that he also had installed a B&M "Shift Stabilizer Kit".
My car's shifter has always felt notchier (which I like - reminds me of my old RX-7) and has been closer to the ebrake than the dash. Now I know why - and I'm changing my position back today ;-)
Data (measure top of ashtry to front of shiftknob@top of boot) in 3rd/N/4th:
Old: (5") (6 1/2") (7 7/8")
New: (7 1/4") (8 1/2") (10")
Now the shifter is much more comfortable and easy to reach.
HIGHLY RECOMMENDED PURCHASE!!!!! - I've got 78,000 miles & never had a problem with it.
BudMan - who thought he lost his marbles with the "off center" hole
[Modified by BudMan, 9:28 AM 1/17/2002]
Ninety3 Integra
Transmission & Drivetrain
17
Apr 13, 2014 05:31 AM
BB1LOViN
Jul 11, 2008 02:28 AM
blackline
Feb 9, 2007 11:07 AM
88EFhatch
14
Jun 8, 2005 06:11 PM
bOOsTiNSoHcVtEc
May 21, 2003 03:25 PM
