got some ?s on z6 head and tb
Old Feb 5, 2005 | 01:30 PM
user 98292739's Avatar
Default got some ?s on z6 head and tb
i just recieved my d16z6 head. i have some questions.
where do i get these bolts and how do i screw them in?
Is this ok? if not how can i fix it?
It seems like the TPS is broken here...easier to just buy a new TB or can i fix this with out to much hassle?
Old Feb 5, 2005 | 01:46 PM
mellon's Avatar
Default Re: got some ?s on z6 head and tb (LoCoReX)
Just get a new TPS from a junkyard. Slot the bolts holding on the TPS with a hacksaw or dremel and use a flathead screwdrive to take them out. Make sure you adjust the new TPS when you replace it.
You can get the bolts in pic #1 from your dealership, or here. I'm not sure about screwing them in, maybe use the double nut technique?
Old Feb 5, 2005 | 06:39 PM
and another thing i am not able to move my cam is this normal? do i have to disassemble the motion assembly to line up the top of the cam? i asked my dad he said i should be able to move the cam but he wasnt sure because he has only messed with a 8 valve not a 16.
Old Feb 5, 2005 | 06:56 PM
EJ2-Fluffy's Avatar
Default Re: (LoCoReX)
Check the Vtec lobs on the very top of the lost motion assembly. Those big holes sitting on top of the rockers arms. They might be stuck, they pop right out. That is what happened to my engine head when it wouldn't move as well.
Jon
Old Feb 6, 2005 | 07:44 AM
ok i just checked those things. they seemed popped out. i can push down on them and what not. I still cant move the cams? dont tell me the head is warped....
Old Feb 6, 2005 | 02:32 PM
no one knows about the bolts?
Old Feb 6, 2005 | 03:59 PM
3RdT's Avatar
those bolts u can get at a dealer or a junk yard. i mite have some but ill have to look for it. to take them out or put them on, what i do is put 2 nuts back to back, make sure their locked tight, n i wrench on the outter nut until the bolts in there.
Old Feb 6, 2005 | 05:07 PM
i should of thought of that...THX! do they have to be torqued in or anything?
Manny86
May 22, 2007 10:17 AM
wfocrx
Apr 6, 2007 01:34 AM
Xemu
11
Aug 30, 2006 09:02 PM
Twisted Image
Mar 23, 2006 08:59 AM
dirtyturtle
12
Aug 4, 2004 10:42 AM
