anyone running big cams with a p8r head?
Old Feb 5, 2005 | 12:44 PM
erebunicrx's Avatar
Default anyone running big cams with a p8r head?
im going to get my b20 with p8r head this week and was wondering if there are any problems i will run into with the bigger valves? im will be running crower 404's
Old Feb 5, 2005 | 05:04 PM
hybrid_vtec's Avatar
Default Re: anyone running big cams with a p8r head? (erebunicrx)
Clay and find out! Probably not, but you may have to grind out the valve reliefs if they are made for the 31mm Intake valves.
Old Feb 12, 2005 | 08:48 AM
bambam's Avatar
no you won't have to grind out the valve reliefs. That head comes on that motor why would he have to modify a stock motor to run a stock head? As for the cams...you won't have any problem. Talk or search for Darkane on these boards. He is running the 404's with his P8R b20b without any problem what so ever. It is a crazy setup for a pretty much stock motor!
Old Feb 12, 2005 | 09:08 AM
erebunicrx's Avatar
forgot to mention i will be running at least 11.5:1 cr pistons
The Honda Dr.
20
Nov 9, 2015 05:05 AM
darrinbrewer
K Series
Jan 18, 2011 02:39 PM
getsome.crx
Jun 10, 2008 04:06 AM
BigBlockCRX
Apr 19, 2005 11:15 AM
ScottEK
Dec 3, 2004 12:55 PM
