Boost vs. NA
Old Feb 5, 2005 | 11:42 AM
one slow coupe's Avatar
Default Boost vs. NA
I know you guys hate these kinds of questions.. But I am debating on whether to go all motor or boost it.
I originally wanted to go all motor when my friend told i can a greddy turbo kit for around 2,600. With the greddy turbo on my car ( 99 si) i will hit low 14s and possibly high 13s.
Well i am thinking will i be able to hit high 13s with this setup?
skunk 2 stage 2s
CTR pistons
Mugen Head Gasket
Omnipower valvetrain
CM lightweight flywheel
CM stage 2 clutch
DC sports JDM 4-1 2.5"
T1R exhaust
Carsound highflow cat
Injen SRI
chipped p28
Would you all recomend new injectors and a fuel pressure regulator?
Or should I go with the greddy turbo and spend 2,500-3,000$? or do that setup and spend about the same amount? Which would be more reliable?
Old Feb 5, 2005 | 12:18 PM
na200whp's Avatar
without major weight reduction a 99si will not see 13's with those mods
Old Feb 5, 2005 | 12:22 PM
VtecKiDD's Avatar
Default Re: (na200whp)
turbo
Old Feb 5, 2005 | 01:37 PM
Red Bull's Avatar
Default Re: Boost vs. NA (Honda_b16a2)
Boost! Boost! Boost!
Old Feb 5, 2005 | 01:48 PM
boosted420a's Avatar
Default Re: Boost vs. NA (RpwrdTurbocoupe)
give your car some torque, boost that bitch!
Old Feb 5, 2005 | 06:11 PM
justBLZE's Avatar
Chopper 2 Hopper
With 200whp, and some weight reduction you can run mid 13s.
Old Feb 5, 2005 | 07:55 PM
totsie7944's Avatar
honestly, i think you will be DAM clsoe to 13's with that setup.. get some bigger injectors, don;t worry about the fuel regulator now. Get some hondata management instead and tune.
It will be close either way. Boost can be expensive though....
Old Feb 6, 2005 | 10:01 AM
dragonz04's Avatar
if your not going to do an ls/vtec w/ the 2-3000 budget, and wanna keep your b16a2 engine as a base, then I would Boost it.
Old Feb 6, 2005 | 10:38 AM
The Specialist's Avatar
Default Re: Boost vs. NA (dragonz04)
B0o0ost it
Old Feb 7, 2005 | 06:13 AM
Default Re: Boost vs. NA (racer_x_eg)
Do you guys think the greddy kit running on 8 pounds will be good enough for high 13s?
Also will 2.5" exhaust be good enough for the greddy turbo bolt on?
Is it possiple to run s2s1 cams with boost?
Old Feb 7, 2005 | 06:27 AM
RobbieG35's Avatar
12 Years Strong
All motor
Old Feb 7, 2005 | 08:08 AM
Adam.'s Avatar
If you are simply looking for more speed you should go with boost. If you plan on doing something like road race/auto-x, think about an h22 or c5 swap with some good boltons and a good tune.
I have an h22 w/ boltons tuned via Uberdata in my 99 ex coupe. I have run 14.0 @ 99.5mph. If I ran slicks or could pull a 2.1 60 foot I would be mid 13s easy.
LudeAchris2001
Apr 28, 2006 06:46 PM
ctr32
Feb 15, 2004 07:37 PM
tygsr
Aug 11, 2002 04:58 PM
dc r-spec
Mar 25, 2002 06:29 PM
