Interior Fan Not Blowing....and I live in Canada
Old Feb 5, 2005 | 08:31 AM
miksew's Avatar
Default Interior Fan Not Blowing....and I live in Canada
engine heats up fine,interior fan does not spin on any setting and i'm freezing
what is the most likely cause of failure?
Old Feb 5, 2005 | 08:41 AM
Magick211's Avatar
Default Re: Interior Fan Not Blowing....and I live in Canada (miksew)
Um this porbally isnt much help but have you checked the fuses? If those are good then maybe the blower motor it self is bad. or the switch
Old Feb 5, 2005 | 08:45 AM
miksew's Avatar
Default Re: Interior Fan Not Blowing....and I live in Canada (Magick211)
how would i check to see if the blower motor is gone? what is the switch?
Old Feb 5, 2005 | 09:08 AM
Eggman's Avatar
check to make sure the cables didnt slip off first. thats the most common problem.
Old Feb 5, 2005 | 12:48 PM
miksew's Avatar
Default Re: Interior Fan Not Blowing....and I live in Canada (Eggman)
checked the cables,found out that they control the temp and not the fans,the fans use a switch and not a cable to control the speed
anyways anyone know how to check if the fan motor went?
Old Feb 6, 2005 | 06:55 AM
mar778c's Avatar
Community Builder
Community Influencer
I had the same problem. I solved it by changing the blower motor. It takes about 1.5 hrs. Do it in a garagr because you will need the room to stretch out.
dyce_b17
Aug 9, 2011 04:39 PM
shadhman
Jan 28, 2009 11:27 AM
schueytenten
15
Aug 8, 2008 12:28 AM
CARflyGUY
Nov 30, 2006 08:57 PM
