No spark - help please!
A few facts:
1988 CRX Si
Car had been running fine, but suddenly started to give me a problem starting. Sometimes, it would fire right up, then a few hours later, nothing. I diagnosed the typical troublespots and here is what I found:
I am getting a code 15 (Ignition Output Signal) from the ECU. No spark at the plugs or at the distributor cap. I checked the coil and igniter with my ohm meter and voltage meter and it all seems fine. I replaced the cap. Rotor is fine. Any ideas on where to look next? Thanks.
1988 CRX Si
do you get a click when you turn the key to start or nothign at all? Have you tried to tap the starter lightly w/ a hammer/stick to see if it would catch as you try to turn it over, if that's the problem.....
Just an idea, right off the top of my head.. Let us know..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drmadness »</TD></TR><TR><TD CLASS="quote">do you get a click when you turn the key to start or nothign at all? Have you tried to tap the starter lightly w/ a hammer/stick to see if it would catch as you try to turn it over, if that's the problem.....
Just an idea, right off the top of my head.. Let us know..</TD></TR></TABLE>
Why would he need to tap on the starter? he didnt say anything about the starter not working.
Do you have any other friends with ef's? If so just try of of their distributors
I would try another coil, seems good and knowing it's good is two different things. Usually, no spark situations are due to faulty ignitors or coils. However, a bad sensor within the distributor may also be a culprit. Like it was suggested, try another known good distributor.
Disconnect the 2 wire connector from the dizzy. Turn the key to the #2 position. Got 12V from blu to ground? Got 12V from blk/yel to ground? What were your primary/secondary resistance readings from the coil?
I checked the two wire connector at the dizzy and it was fine - read just at 11 volts. Continuity was good from all wires in the dizzy (coil, ignitor, 2P connection). Ohm readings on the coil were about 12,000 at the secondary side. At the primary side, it was very difficult to read because my meter has a calibration wheel on it and the slightest movement shifts the reading from 0 to 1.5 ohms. I checked a brand new coil and it read the same on the primary side. I know the coil is fairly new, but not sure I can get a very accurate reading in the low range of my ohm meter.
I did some more checking of the wiring and this is what I found. I probed the blue wire going to the ignitor and grounded it with my ohm meter and the needle barely moved. I also did the same with the white wire on the ignitor (mine is not white, it looks to be yellow/blue) and it read the same - very little continuity. I then began suspecting a poor ground somewhere. I disconnected the 2P connector at the dizzy and probed the blue wire and grounded it - same thing, very little movement on the ohm meter. Does this sound like a poor ground to you? If so, where should I trace this back to? I checked the ground on the thermostat housing and it is on very tight. Looks like it hasn't been off in years. Thanks again
Grounds Cuz some funny ****. last time i was having Eletrical problemd i Complety replaced my main body ground and added a few more. Plus a bigger ground was added to the transmission. Problems went away.
So just remove each one and clean/inspect them. Oh and check the plugs on your harness to, make sure they go together tight and arent broken. Thats everytrhing i can thing of. good luck
OK, here we go. On Sunday afternoon, I pulled all the connectors on the harness apart, including the connections at the ECU. Put everything back together. I am still using the same igniter and coil. The car started right up and ran fine all day Sunday and Monday. Tuesday morning, won't start again...it seems like this happens primarily in the cooler temperatures of the morning. What do I look for?
dose your dizzy cap seal all the way could be moist inside if not, my car was having the same problems changed the dizzy ran like new, try swaping the dizzy out for another one and try that out if you need one i have a few, let me know hope to help fix your troubles man
The cap is new and it is tight fitting. Thanks for the offer on the dizzy. I believe my problem is related to the main relay. It always seems to start when the temp. outside warms up. I am going to change the main relay and see if that fixes things.
