Whats that noise???
Old Jan 15, 2002 | 04:44 PM
MattG's Avatar
New User
Default Whats that noise???
I installed a Comptech tie/sway bar. 2 weeks later there is an occasional noise from the rear (suspension?). All the bolts are tight to spec torque. It was at the dealer for some warranty work and they checked it out. The noise only happens occasionally, most often when one rear wheel drops into a dip or something and mostly in parking lots where the pavement has very small rolls. This is driving me crazy. Any suggestions?
Its a 2000 GSR.
[Modified by MattG, 5:44 PM 1/15/2002]
Old Jan 15, 2002 | 04:47 PM
Chris's Avatar
Default Re: Whats that noise??? (MattG)
I had that exact noise. It was an endlink bushing gone bad.. check all the rubber bushings.
Old Jan 15, 2002 | 04:58 PM
crr's Avatar
crr
speaking of noises... after driving forward for a while, when I backup, say, into a parking spot, I get a clunking noice when I hit my brakes. I suspect it's just my brake pads moving - as it coincides exactly with my hitting the brake peddle and I tend to hear it on all corners (sometimes on select corners). It only happens when backing up - and I don't need to be in reverse, as it does it when I'm on a hill and let the car roll backward.
I'm inclined not to worry about it, but since I'm posting this reply, I guess I'm curious if anyone else experiences this?
Thanks.
Old Jan 15, 2002 | 04:59 PM
Chris's Avatar
Default Re: Whats that noise??? (crr)
Its the pads re-settling. Normal.
Old Jan 15, 2002 | 05:02 PM
crr's Avatar
crr
Default Re: Whats that noise??? (Chris)
That's the fastest reply I've ever gotten. Thanks Chris.
crr
'98 RS
Old Jan 15, 2002 | 05:05 PM
Chris's Avatar
hehe Im on it tonight. (or Im trying to be!)
kcari
Suspension & Brakes
12
Mar 29, 2011 06:34 PM
GAngulo7
Honda Civic (2001 - 2005)
Jan 26, 2010 08:17 PM
skip.two
Suspension & Brakes
Jun 14, 2009 07:38 AM
Yambor
May 1, 2006 03:15 PM
