dashpot on the throttle body?
anyone knows if youe need that dashpot on the throttle body or can it come off cuse i took mine off and dont know if i should put it back on? any advice? please help
ok not trying to be dumb put i took it oof should i put it back on. and since i did take it off i sotra notice it dont like to stay running till it gets warm up lil bit is this why?
I just had a problem that was resolved by adjusting the positioning of my dashpot because it was crooked. Seems I had a problem with 4000 rpm revs when I started the car, so yeah, I'd leave it.
This one? I just removed it. Haven't felt any different. Have an idea that it adjusts the idle when it's reeaaally cold outside (Like -10-20-30 Cs). If you pull on it, it will only make the engine rev up to 3000rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc »</TD></TR><TR><TD CLASS="quote">yea thats it so ill be fine runing with out it </TD></TR></TABLE>
You should have no problems. I cut mine off...never had any problems.
every morning when its cold out m car turns over, stalls then it stsrts right up. it just helps it out when its cold.during the summer no problems, i dont really get it though my last b16 didnt even have one and didnt do what my motor does now. i wouldnt even worry about it to much no biggie.
mkinpwrat12g's
Sep 1, 2005 07:12 AM
