Questions for the "BIG" cam guys
Hey,
Here is my setup:
JDM B18c-r
TODA pistons,valve train, spec b cams
Eagle H-beam rods
82.5 mm bore
12.5:1 cr
My question is, I was thinking about stepping up to the spec "c" cams, but I want to know if anyone has had any experience with them. Is there going to be a big difference btw the b's and c's or maybe the s2s3's would be a better idea.
Any idea's????
Modified by TypeRcivic at 8:50 PM 2/4/2005
Modified by TypeRcivic at 8:53 PM 2/4/2005
Here is my setup:
JDM B18c-r
Eagle H-beam rods
82.5 mm bore
12.5:1 cr
Any idea's????
i'm gonna guess the toda b's will give you a better overall powerband, while the skunk2 stg3 will have less low-end/midrange, but a considerable amount more of top end if tuned properly.
Why spend the amount of $$ when you could buy a cheaper camshaft and make more power?? SOOO many cams out there will pull over a Toda C. The C's have a considerable amount of lift, but the duration is way weak. Do some more research and find some more dyno's, also, where do you want to make your power and where do you want it to peak??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRcivic »</TD></TR><TR><TD CLASS="quote">Hey,
Here is my setup:
JDM B18c-r
Eagle H-beam rods
82.5 mm bore
12.5:1 cr
Any idea's????
Modified by TypeRcivic at 8:53 PM 2/4/2005</TD></TR></TABLE>
Do you use stock slevees with that 82.5 mm piston??
s2s2
Here is my setup:
JDM B18c-r
Eagle H-beam rods
82.5 mm bore
12.5:1 cr
Any idea's????
s2s2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL »</TD></TR><TR><TD CLASS="quote">i'm gonna guess the toda b's will give you a better overall powerband, while the skunk2 stg3 will have less low-end/midrange, but a considerable amount more of top end if tuned properly.</TD></TR></TABLE>
your not gonna see a HUGE change b/t the toda b's and c's. Just powerband differences.
Yes. Stock sleeves. I thought about re-sleeving, but I decided it would be a Type r anymore. I guess my next all motor will be either a B18c1 or B20
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeRcivic »</TD></TR><TR><TD CLASS="quote">Yes. Stock sleeves. I thought about re-sleeving, but I decided it would be a Type r anymore. I guess my next all motor will be either a B18c1 or B20</TD></TR></TABLE>
RESLEEVE THE BITCH
RESLEEVE THE BITCH
luis666
Mar 21, 2006 09:07 AM
JDMsurf
Jan 6, 2005 04:20 PM
