b18b1 into first generation integra?
Old Feb 4, 2005 | 04:47 PM
95integralshere's Avatar
Default b18b1 into first generation integra?
Hey everyone, been a while since my last post. I just sold my 1995 integra ls, and now i have a beater 1989 integra ls. I think its got a d16a1 if im not mistaken. One thing i was wondering is i thought only B series motors were dohc and D series meant sohc? Im 100% sure this one is dohc. I was also wondering how difficult it is to install a b18b1 into my 1989 integra? I figured it would be the best bang for the buck. Is alot of modification nesseccary? is there another motor swap that i would benefit more from? thanks in advance for your help.
Old Feb 4, 2005 | 04:52 PM
rgaray's Avatar
Yup, alot of mod. You could try doing a ZC swap.
Old Feb 4, 2005 | 05:20 PM
93tegy's Avatar
Default Re: b18b1 into first generation integra? (95integralshere)
I would just do a b16.
Old Feb 4, 2005 | 06:28 PM
HiRevn's Avatar
Default Re: b18b1 into first generation integra? (93tegy)
My brother had a 89 RS Integra and it definitely had a DOHC engine. Acura did not sell any SOHC Integras in the US.
Old Feb 4, 2005 | 09:08 PM
thanks for the comments. Anyone know if theres any heavy modification in installing a b16a into my 89 integra?
Old Feb 7, 2005 | 08:37 PM
anyone own this car that can tell me if theres anything i should look for or check out? Im sure since its an integra it will run for a while, is there any common problems that seem to have? thanks in advance.
Old Feb 8, 2005 | 10:05 AM
95lstegman's Avatar
Default Re: (95integralshere)
what you have is a D16A*, and this one is the one commonly referred to as ZC. it is twin-cam, and comes with 120hp in '89. it's a pretty good engine, really. i wouldn't bother swapping to LS. what i would do is get JDM ZC pistons for higher compression, and rebuild the whole engine with them since it's old and a full rebuild if you do all the labor is $700-$750ish (PM if you want to bitch). oh yeah, and you can get the valve spring recesses line-honed for LS valve springs and pick up some nice cams. boom. plenty of fun for a daily driver w/o breaking the bank. i'm assuming you have around the $1k-$1.5k it would take to complete this stuff since you're considering an engine swap.
oh yeah, and B-swap in that car won't fit power steering or air conditioning. and putting on the alternator requires some bashing with a BFH.
Old Feb 8, 2005 | 10:25 AM
purplegsr's Avatar
Default Re:
check out http://www.g1teg.org, it's been done a few times over there, and they have more expertise on 1st gens.
Old Feb 10, 2005 | 10:31 PM
thanks for the help.
Does anyone know if the lowering springs i got for my 95 integra will work on my 89 integra? thanks.
Old Feb 10, 2005 | 10:56 PM
purplegsr's Avatar
Definitely not in the front, it's a torsion bar system (basically you can think of it as the shocks being mounted upside down). The rears I think use the same shocks (or can be adapted to) as the EF/DA, if that's the case, then you could use the rears from a 95 Integra. Read in the how-to section on g1teg.org
Old Feb 11, 2005 | 08:41 PM
sleepinbeauTEG's Avatar
Default Re: (purplegsr (Exospeed))
yeha i have a 1990 teg and i put a b18b in my car.....a few things needed to be fixed like i had to use my old ditirbutor on the new motor cuase of hte wiring....the old exhaust manifold, and the old wiring harness...other then that its straight...oh besides the drivers side engine mount it sits kinda crooked
racereaper7
Jan 22, 2008 04:37 PM
bOOsted_D16
10
Apr 26, 2006 04:46 PM
deltaforcehall
Aug 27, 2004 08:42 PM
VtecKiDD
23
Jan 26, 2004 12:46 PM
