Charcol canister/
Old Feb 4, 2005 | 02:21 PM
Magick211's Avatar
Default Charcol canister/
Im swapping in a 98 ls motor and there is no place to hook the hoses that come from the charcol canister.... I know i could porbally get a older ls throttle body maybe but i would really like to stick with the one that is ont he motor now..
How bad is removing the charcol canister? Is it wise?
Old Feb 4, 2005 | 02:25 PM
kulangot's Avatar
Default Re: Charcol canister/ (Magick211)
whats up mike, not for sure on that but i have ls t/b u can have...
Old Feb 4, 2005 | 03:11 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Magick211 &raquo;</TD></TR><TR><TD CLASS="quote">Im swapping in a 98 ls motor and there is no place to hook the hoses that come from the charcol canister.... I know i could porbally get a older ls throttle body maybe but i would really like to stick with the one that is ont he motor now..
How bad is removing the charcol canister? Is it wise?</TD></TR></TABLE>
Since you don't live in CA, or if texas does not have strict emissions, I would take it off. I live in FL and have no use for it being there. Since you have a 98 ls motor, i'm assuming the map sensor vacuum thingy is on the t/b, so you can probably tear that out as well.
Old Feb 4, 2005 | 03:16 PM
Magick211's Avatar
Default Re: Charcol canister/ (Mach69)
Yeah i tore the fire wall mounted map out.
Old Feb 4, 2005 | 03:20 PM
kulangot's Avatar
can i have it?
Old Feb 4, 2005 | 04:59 PM
Magick211's Avatar
Default Re: Charcol canister/ (sirq2u)
Well im guessing the red hose from the canister goes to the evap purge on the intake manifold. (not quite sure) but the two vacum hoses comming off the canister still have no place/ anyone have any ideas?
How about some egine bay pics so i can see what others have done. I have searched
Old Feb 5, 2005 | 03:29 AM
ijjz's Avatar
I thought the charcol canister was only used on older engines like OBD-0's and such.
Old Feb 5, 2005 | 04:16 AM
fireant's Avatar
Default Re: Charcol canister/ (ijjz)
My '00 D-series motor doesnt have a charcaol canister. I dont think the 98 LS motor had one either. I'd say remove the canister and save it in a box somewhere.
Old Feb 5, 2005 | 08:33 AM
Magick211's Avatar
Default Re: Charcol canister/ (fireant)
well i do think the newer cars have some kinda evap cansiter, but i think im just gonna remove my charcol cansiter.
froogle29
Jul 23, 2008 04:56 PM
Houston Hatchback
May 14, 2003 11:45 AM
