TWM ITB's on K20 Type R Install?
Old Feb 4, 2005 | 10:01 AM
TypeR_Turbo's Avatar
Default TWM ITB's on K20 Type R Install?
has anyone installed these before? we have a set here but oncewe have put the ITB's on the water pump will not fit unless the tensioner bracket is cut off......i will have pics up in a couple hours.
Old Feb 4, 2005 | 10:35 AM
Default Re: TWM ITB's on K20 Type R Install? (TypeR_Turbo)
Old Feb 4, 2005 | 10:45 AM
Hondog's Avatar
I had to cut the tensioner bracket of my water pump. Be careful how much you cut off. I beleive the monkey that cut mine cut it to low and had to weld it up again.. What size ITB's did you get and did you make an adapter plate or port the head to match the runners to the ports?
Old Feb 4, 2005 | 10:53 AM
SuperTwinz's Avatar
Default Re: TWM ITB's on K20 Type R Install? (Hondog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondog &raquo;</TD></TR><TR><TD CLASS="quote">I had to cut the tensioner bracket of my water pump. Be careful how much you cut off. I beleive the monkey that cut mine cut it to low and had to weld it up again.. What size ITB's did you get and did you make an adapter plate or port the head to match the runners to the ports?</TD></TR></TABLE>I believe TWM makes ITBs for the K20A heads.
Old Feb 4, 2005 | 11:37 AM
yeah i measured it and i can cut the top part off and still bolt the tensioner back on......we are going to port match the head to the gasket........they are the TWM 50mm itb's
Old Feb 4, 2005 | 03:20 PM
Hondog's Avatar
well if I get time I will open my 52mm ITB's and take a pic. the runners are huge compared to the ports, you can actually see the side of the head all the way around the ports. Thats on my K20A-R although in about 2 weeks that will all change along with the cams etc.. Hmmm power and 10's here I come..
Old Feb 4, 2005 | 03:59 PM
chameleon's Avatar
droooooool.
Old Feb 6, 2005 | 08:46 AM
evilxkid's Avatar
Default Re: TWM ITB's on K20 Type R Install? (chameleon)
i had to cut the tensioner off too...
Old Feb 6, 2005 | 04:24 PM
VG! girL's Avatar
looking sexy....
k motor+ITBs=sexy
Old Feb 8, 2005 | 09:53 AM
Default Re: TWM ITB's on K20 Type R Install? (VG! gurlie)
i'll post pics and dyno sheets when installed and done! thanks for all the replies guys....hope it works out good which i think it will work great
Old Feb 8, 2005 | 10:00 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: TWM ITB's on K20 Type R Install? (Manuel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Manuel &raquo;</TD></TR><TR><TD CLASS="quote">Ask Pacman they all read did itb's on a K20R</TD></TR></TABLE>
He used the 52mm ones like Hondog didn't he?
Old Feb 8, 2005 | 10:23 AM
Hondog's Avatar
Default Re: TWM ITB's on K20 Type R Install? (rochesterricer)
Yeah pacman was running 52mm ITB's he tried the 50mm but the 52mm made better power even without being match ported..
Old Feb 12, 2005 | 09:32 PM
95eg6's Avatar
good info
Old Feb 13, 2005 | 01:46 AM
They Call Me Bizzare's Avatar
They Call Me Banned
Default Re: TWM ITB's on K20 Type R Install? (Ekay4)
im jelous..thats one beautiful motor you have there..
sorry for the useless post
Old Feb 27, 2005 | 08:21 PM
vaughn4's Avatar
Default Re: TWM ITB's on K20 Type R Install? (They Call Me Bizzare)
i really want to see some pics.. i have the 52mm TWM set here.. does anyone know what part # belt you have to use after removing the idler pulley and auto tensioner? plus, can you just notch the underside of the hood on the EG to get them to fit... or will i have to cut out the hood to get them to fit?
Old Apr 2, 2005 | 01:25 PM
bunnyrabbit's Avatar
bump
Old Apr 2, 2005 | 02:52 PM
Professor15's Avatar
Damn those look sexy! i cant wait until i get mine lol....ahhh soon....
Old Apr 3, 2005 | 08:30 AM
the buddha's Avatar
Default Re: (drchulo)
nice where did you get those share
Old Apr 3, 2005 | 01:13 PM
Itbdennis's Avatar
Looks nice,
sorry i can't help ya didn't install my itb's myself. ( my car is not running at the moment )
greetzz dennis
Old Apr 5, 2005 | 08:54 AM
Peter K's Avatar
New User
Default Re: TWM ITB's on K20 Type R Install? (Itbdennis)
What do you k series guys use to tune for itbs? kpro?
Old May 13, 2005 | 01:18 AM
BodyKits NW's Avatar
Default Re: TWM ITB's on K20 Type R Install? (Peter K)
How much does that setup run. Looks spendy.
Old Oct 2, 2005 | 10:10 AM
HomeDepotMade's Avatar
Default Re: TWM ITB's on K20 Type R Install? (BodyKits NW)
thas sick man. TWM and toda makes ITBs
Old Mar 6, 2006 | 10:58 PM
V-SPEC 1's Avatar
Default Re: TWM ITB's on K20 Type R Install? (vaughn4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaughn4 &raquo;</TD></TR><TR><TD CLASS="quote">i really want to see some pics.. i have the 52mm TWM set here.. does anyone know what part # belt you have to use after removing the idler pulley and auto tensioner? plus, can you just notch the underside of the hood on the EG to get them to fit... or will i have to cut out the hood to get them to fit? </TD></TR></TABLE> I'd like to know as well. Sorry to bring this up again.
Old Mar 7, 2006 | 01:14 AM
rodimus's Avatar
Default Re: TWM ITB's on K20 Type R Install? (V-SPEC 1)
check out IPS's intake manifold.
i believe it outperformed ITB's.
Old Mar 7, 2006 | 10:18 AM
yee SERIOUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by They Call Me Bizzare &raquo;</TD></TR><TR><TD CLASS="quote">im jelous..thats one beautiful motor you have there..
sorry for the useless post </TD></TR></TABLE>
me too....that is one sweet setup.
