Is it possible to convert 98 gsr 4-lug wheel set to 5-lug ?
Old Feb 4, 2005 | 10:01 AM
integraboi1010's Avatar
Default Is it possible to convert 98 gsr 4-lug wheel set to 5-lug ?
If so, how much would it cost and what do I need to get?
Old Feb 4, 2005 | 10:16 AM
You_Get_Vapors
Guest
Posts: n/a
Default Re: Is it possible to convert 98 gsr 4-lug wheel set to 5-lug ? (integraboi1010)
Yes. It's called a 5 lug conversion. You will need the suspension from a 98-01 Integra type r or civic type r. You will need the wheel bearings, hubs, rotors, ball joints, and axles (ITR). Not sure if you need the trailing arms, LCAs or brakes.
Old Feb 4, 2005 | 10:30 AM
dFreezy's Avatar
Default Re: Is it possible to convert 98 gsr 4-lug wheel set to 5-lug ? (You_Get_Vapors)
search in the archives, many useful threads:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">» Search Results
Your search for lug conversion returned 614 results.</TD></TR></TABLE>
egraffitti
Suspension & Brakes
May 7, 2010 07:57 PM
zhen_fai
Oct 8, 2008 09:18 AM
kcjohnnyboy
Suspension & Brakes
Jun 21, 2005 10:22 PM
ekzrated
Feb 20, 2005 06:33 PM
Project X
Jun 29, 2004 07:06 AM
