b18b obd2 swap help...
Old Feb 4, 2005 | 08:06 AM
Magick211's Avatar
Default b18b obd2 swap help...
Ok im swapping in a obd2 ls, but i will be using obd1 ecu, What is the sensor on top of the intake manifold to the left of the map sensor?
I bileve it is the "Evap Purge valve" If so what do i do with it? cause there is a place for a hose to hook up and a clip.
Old Feb 4, 2005 | 09:15 AM
Rywire's Avatar
Default Re: b18b obd2 swap help... (Magick211)
If you have the evap purge on your cars firewall anyway, just remove it from the b18b intake mani.
Ryan
Old Feb 4, 2005 | 11:42 AM
Magick211's Avatar
Default Re: b18b obd2 swap help... (droppedcrxsi)
Ok thanks man
PROJECT 91
Nov 19, 2006 02:41 PM
I got a honda
Jan 15, 2006 07:17 PM
kyden
Mar 21, 2005 09:14 AM
legendboy
Jan 6, 2003 07:02 AM
todds94teg
Jun 24, 2002 12:32 PM
