Setting Timing Belt Tension
Set the No. 1 piston at TDC .
Rotate the crankshaft 5-6 revolutions to set the belt.
Loosen the adjusting bolt 1/2 turn (180°) only.
Rotate the crankshaft counterclockwise 3 teeth on the camshaft pulley.
Tighten the adjusting bolt.
After adjusting, retorque the crankshaft pulley bolt to 130 ft. lbs
thats from alldata
thats from alldata
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96MidoriHatch »</TD></TR><TR><TD CLASS="quote">Set the No. 1 piston at TDC .
thats from alldata
Thats fine with stock head gasket and head, but mill the head and/or run a thinner head gasket, and 3 teeth will leave the belt loose.
thats from alldata
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BryanPendleton »</TD></TR><TR><TD CLASS="quote">
Thats fine with stock head gasket and head, but mill the head and/or run a thinner head gasket, and 3 teeth will leave the belt loose.</TD></TR></TABLE>
yup.
coathanger or screwdriver is how I do it.....
yup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">
yup.
But again, HOW TIGHT do you go? How do you measure the tension in the belt, once you have tightened the tensioner? Do you measure deflection of belt on long side between crank and exhaust cam? Or what?
yup.
</TD></TR></TABLE>But again, HOW TIGHT do you go? How do you measure the tension in the belt, once you have tightened the tensioner? Do you measure deflection of belt on long side between crank and exhaust cam? Or what?
im sure this isnt the most accurate test, but i have always just held the belt between my thumb and index finger and turned it 45 degrees if you cant do that its too tight, if it goes farther its too loose
sorry to bring this from the dead.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96MidoriHatch »</TD></TR><TR><TD CLASS="quote">im sure this isnt the most accurate test, but i have always just held the belt between my thumb and index finger and turned it 45 degrees if you cant do that its too tight, if it goes farther its too loose</TD></TR></TABLE>
is that a good way to test how tight the belt should be? I have gotten the belt on the intake take side pretty tight and on top of both cam gears, but the belt that is on the exhaust cam seem to wobble alot at idle. My question is the belt suppose to look like it's always tight at different rpm. I don't want my cam gear to jump a tooth.
cool that's what i though. I'm going to see if i can tighten it a bit more. Now if it's too tight would i nap the belt at 8600 rpm? i plan and going to the drag strip soon.
