beaks instructions
hey guys i just got the beaks subframe kit for my dc, with no instructions. i tried downloading them off of the beaks site with no luck. anyone have instructions or know where i could find em'. thanks
It's very similar to installing the BSQ kit so just follow these instructions:
http://geocities.com/bretq/swaybar_install.html
If you dont know how the parts go together...Here:
VS
BSQ
VS
BSQ
Sorry, I gave you the wrong link...
Here:
I edited my original post and put the correct link there also.
p.S. Here it is in PDF format:
http://www.geocities.com/bretq...n.pdf
Here:
I have a Word document with some Beaks install instructions that I must have saved from a post on some message board or from someone's website. I'll link it from my machine below...
http://theterritory.servebeer.com/BEAKS/
Not real detailed, but it does include some pics.
JD
JD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR »</TD></TR><TR><TD CLASS="quote">It's very similar to installing the BSQ kit so just follow these instructions:
You can use my BSQ installation instructions when using the Beaks kit. The only difference is, you will need to remove 4 additional tacked-welded nuts from the back-side of the subframe. There are 2 on each side that were used for the original swaybar. You will also need to either remove or modify the ABS sensor wire bracket.
Also, if you get the dreaded "exceeded bandwidth" message on my website, you can try my mirror site at http://geocities.com/bretq2/swaybar_install.html .
ITRfaithful
Jul 2, 2002 12:59 AM
240sxtc
Jun 7, 2002 01:21 PM
bar, beaks, bsq, buy, ep3, instalation, install, installation, installing, instruction, instructions, instuctions, kit, s2000, subframe
