sohc non vtec vs. sohc vtec
debating on witch one. im planing on an a6 bottom end with forged rods and pistons.
around 10.5 comp and a large shot of nitrous.
i hate how u cant cant really adjust the timing if you use a6 dist. on the z6 head, and i dont really know if i want to spend the money on z6 dist. ecu and odb1 conversion harness.
will i really be at that much of a disavantage using the a6 head if i get a cam 3 angle valve job and light port work.
i know that u can adjust it but the holes are egged out so bad that the metal is paper thin and u can only use 2 bolts i just dont really like it like that
tired of every think on my car being getto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter »</TD></TR><TR><TD CLASS="quote">you can still adjust timing with that dist.</TD></TR></TABLE>
honda heads already have 3 angle valve job.
if you're tired of being getto just spend the cash and get the z6 dizzy and jumper harness
thanks for all the input.
i have both heads and have used both.
its just with the price of the a6 cams being very cheap would how much of a disadvantage would it be
i have been lookin at some exospeed stuff
it just seems like i might be a bit simpler.
and i was planing on redoing what ever head i do use
You can make some get power with the a6 , but u also gotta be willin to sacrifice gas mileage and a lil low end. The point of vtec is to have low end torque, high end hp, and a non-aggressive streetable cam profile for good gas mileage. I have a Delta 272 camshaft in my a6, pulls harder than my buddies a6/z6 mini-me. Best 100 i ever spent.
EJgsr
Oct 12, 2006 06:23 PM
IamVtec
Feb 11, 2003 05:56 PM
LXguy
Jan 21, 2002 09:52 AM
