Spark Plugs Too Tight
I'm just hoping to god that hes twisting counter clockwise... I knew an idiot that twisted it clockwise before and stripped out his head. Cheapass replaced it with a helicoil and sold the car.
Anyway, I would just try to get the car to operating temp and try to removed them then.
Sorry teken- but I wouldn't go putting pipes on ratchets when working with spark plugs- I had an 89 civic come to the shop once with the original plugs in it (2 years ago) and I did everything I could to get the plugs out- the # 2 plug hex broke off- the plug was broken in half!! The head had to be pulled and sent to a machine shop. I find the best method is to spray a good amount of penetrating oil down the hole- let it sit for a while- turn it a little- if it doesn't get easier- screw it back in- wait a little- remove it some more- it will eventually come out. Anti seize is not a bad idea- but it is not completely necessary if you use denso or NGK plugs that are replaced every 30k miles. Leave those champions and bosch plugs for your lawnmower (if it's not a Honda too).
I'm just wondering, please explain to me, why heating would loosen the plugs. My first impression is that the plug and head expansion would only make them tighter. Seriously i'm not being snotty, just want to know for future reference.
BoydCivic2005
Honda Civic (2001 - 2005)
Dec 17, 2013 08:50 AM
busta7777
Feb 9, 2011 04:01 PM
