Greddy oil temp gauge quirk??
Old Feb 3, 2005 | 04:21 PM
mugenracer's Avatar
Default Greddy oil pressure gauge quirk??
I just noticed this today, when driving at a steady accelerating rate in 2nd or 3rd gear (not WOT) the oil pressure needle rises steadily to 6kg/cm (85psi) but as soon as it hits 6kg it drops immediatley back to 5.5kg/cm (78psi) and remains there...ie this is maximum pressure...when driving at WOT in 4th or 5th gear it rises to 6kg, again drops to 5.5 but then rises and remains at 6kg/cm...it seems to be working fine otherwise. It idles at 25 > 28psi..usually at 28 (2kg/cm) and the needle sweeps very smoothly, like ist not jumpy or anything. Is this normal or is there something up with it?
Modified by mugenracer at 3:49 PM 2/4/2005
Old Feb 3, 2005 | 06:20 PM
Philly_NBP_R's Avatar
Default Re: Greddy oil temp gauge quirk?? (mugenracer)
totally normal. There is a relief valve that pops at a certain pressure...
Old Feb 3, 2005 | 07:09 PM
Chris F's Avatar
Default Re: Greddy oil temp gauge quirk?? (Philly_NBP_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">totally normal. There is a relief valve that pops at a certain pressure...</TD></TR></TABLE>
Yep! Same thing here.
Old Feb 4, 2005 | 04:46 AM
mugenracer's Avatar
Default Re: Greddy oil temp gauge quirk?? (Chris F)
Thanks...i never knew that
Old Feb 4, 2005 | 06:20 AM
ZygSpeed's Avatar
That would most likely be when the VTEC solenoid lets oil into the mechanism that switches from the lower to higher cam lobes, which in a stock ITR ECU is @ 6K rpm.
Old Feb 4, 2005 | 06:23 AM
Default Re: Greddy oil temp gauge quirk?? (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">That would most likely be when the VTEC solenoid lets oil into the mechanism that switches from the lower to higher cam lobes, which in a stock ITR ECU is @ 6K rpm. </TD></TR></TABLE>
maybe, but it relieves pressure regardless of the current RPM. The oil pressure ALWAYS stays below 6 kg/c cm (which can be reached at 2000 rpm on up, depending on oil temp).
Old Feb 4, 2005 | 07:36 AM
Chris F's Avatar
Is the bypass just the bypass in the oil filter itself? That was my original impression. I don't know what other bypass exists.
Old Feb 4, 2005 | 07:54 AM
there is a relief valve on the oil pump - it's number five in the above diagram.
Old Feb 4, 2005 | 01:56 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Philly_NBP_R &raquo;</TD></TR><TR><TD CLASS="quote">[img]
there is a relief valve on the oil pump - it's number five in the above diagram. </TD></TR></TABLE>
Thanks a lot! I was wondering where that was.
-Chris
Old Feb 4, 2005 | 02:11 PM
IN VTEC's Avatar
Same deal with mine when I had it. Altho, I've never actively looked for it on other brands of gauges.
Old Feb 4, 2005 | 02:51 PM
mugenracer's Avatar
I just noticed i have 'temp' instead of 'pressure' written in the thread title...its amazing that none of the H-T vultures jumped on that one!
Old Feb 4, 2005 | 03:01 PM
KOALA YUMMIES's Avatar
Default Re: (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">I just noticed i have 'temp' instead of 'pressure' written in the thread title...its amazing that none of the H-T vultures jumped on that one!</TD></TR></TABLE>
Its because this was a very good useful question!
Old Feb 5, 2005 | 08:24 AM
vtec.dc2's Avatar
your topic made it clear it was pressure.. anyway, i have same thing happening
turbotime
Jul 11, 2006 08:26 AM
ham
May 4, 2005 07:24 PM
ActiveAero
Feb 11, 2005 09:41 PM
degradated
Oct 29, 2001 07:04 PM
degradated
Oct 28, 2001 05:51 PM
