Engine is acting funny. what is the problem?
Old Feb 3, 2005 | 03:21 PM
UnknownAccord's Avatar
Default Engine is acting funny. what is the problem?
I have a 2000 accord v6 sedan. And today after getting my haircut, i come back to start the car, but when i turn the key the starter motor works but the engine dont start and also the battery light and oil light came up. Then i start it again, the engine starts but the rpm tachometer fluctuates alot under the the 1ooo point, moving up little then down. And also i can hear the engine sputtering or shaking.
So i give it some gas while in park and warm the engine up. The Engine stoped suttering. and i drive my car home, but when I stop at red lights i can see the rpm tachometer fluctuating somewhat but the engine does not sputter. I got home and parked it, the tachometer still fluctuates and the engine sort of trieds to die on it self.
Can anybody tell me the reason why this is happening to the car. I not very good with cars and stuff, so any help would be great. Thanks in advance.
Modified by UnknownAccord at 12:54 AM 2/4/2005
Old Feb 3, 2005 | 06:36 PM
TxTuner
Guest
Posts: n/a
Default Re: Engine is acting funny. what is the problem? (UnknownAccord)
need to know if this is AT or MT. More than likely your idle needs to be adjusted
Old Feb 3, 2005 | 08:31 PM
tournapart's Avatar
start simple and work you way to the more expensive parts. the first thing i would cheack is the sparkplugs, im not sure if new honda motors have coil packs right above the sparkplugs or if they still have wires. all the cheap **** basically, then i would guess the alternator if everything else doesnt fix it .
sunfire
Mar 3, 2016 09:05 PM
CaliforniaSnow
Feb 12, 2014 08:00 PM
sgrahame21
Aug 31, 2006 08:31 PM
trustbuddy
Jan 15, 2006 12:25 PM
Shinbo
Nov 7, 2004 11:16 AM
