H22 bogging/misfiring question
Old Feb 3, 2005 | 11:15 AM
non_Vtec4700's Avatar
Default H22 bogging/misfiring question
I have a 1993 accord with a 93 usdm h22 motor, skunk2 intake manifold, NX direct port, and VAFC and i have a problem when the car starts up and is running.
When my engine is warm or cold it has a rough idle. When i start moving my car it will bog for a few seconds then clear up and it will not do it anymore. When it is bogging i can hold the throttle at any position and it will still bog. Also my car always seems to have a slight misfire and it backfires hardcore. I also have a direct port nitrous set up on my car and as soon as nitrous hits it bogs/hesitates for a split sencond and then it clears up. I have changed the the injectors, the fuel pump, the fuel pressure regulator, spark plugs, tuned V-AFC, and checked V-AFC wires. Could it be the plug wires, the coil, or the O2 sensor??? I don't know...I am stuck. Any ideas would be helpful.
Thanks
Old Feb 3, 2005 | 11:20 AM
mgags7's Avatar
check the map sensor and the fuel pressure regulator....
sounds like your car just richens out real bad, so check those two.....
maybe even get one of those cheap b&m fuel pressure guages and see if all your lines and injectors are ok.....
Old Feb 3, 2005 | 09:08 PM
Default Re: (mgags7)
I have already changed my fuel pressure regulator and injectors, i haven't checked the map sensor but i will do so. Thanks for the input. post back if you have anymore ideas. Also i have noticed that on my first cyliner spark plug it is black/brown, and the other three spark plugs show white.
metal craft
Jan 25, 2008 03:47 AM
ilikehonda
Oct 23, 2006 09:10 AM
13secondmonster
May 14, 2004 07:23 AM
NirVTEC
Dec 3, 2003 12:44 PM
Kp_VtekNiks
Sep 20, 2003 12:15 AM
