What Spark Plugs do you all-motor racers use on B-series
Recommendations on Spark Plugs on a B-Series, 2.2l, Ethanol, 15:0.1, Crane Rollers, dry-sump, etc. etc.
Racers please chime in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcter g »</TD></TR><TR><TD CLASS="quote">I will be using NGK in my 13.5:1 LS......One plug colder than recommended.</TD></TR></TABLE>
Damn, when did a 13.5:1 LS happen?!
For alcohol, you are going to want to run at least 2 steps warmer of a plug to ensure that you are going to get adequate atomization of the fuel. Standard copper core NGK's will do the trick. I believe heat range 3 and 4's are special order plugs, but NGK does make them. Stock heat range is 6 for reference.
usse teh VX plugs ... you need to clean them after each race with ethanol ... just like you would your fuel injection system with gas after each event.
here's ngk's number ... you need the electrode that does not protrude too much into chamber (assuming you have huge domed pistons)
NGK Spark Plugs (U.S.A.), Inc.
6 Whatney
Irvine, CA 92618
tel: 949-855-8278
fax: 949-855-8395
Wixom, MI
tel: 248-926-6900
fax: 248-926-6910
greg
6 Whatney
Irvine, CA 92618
tel: 949-855-8278
fax: 949-855-8395
Wixom, MI
tel: 248-926-6900
fax: 248-926-6910
greg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EMO-anthony »</TD></TR><TR><TD CLASS="quote">Modified Autolites by Rocket!
You are rebuilding your LS? What are you using to get 13.5:1? I finally got mine dyno'd, check my sig and click on "My Dyno and Setup"
BTW I use NGK BKR7E's
Modified by hybrid_vtec at 7:37 PM 2/3/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 »</TD></TR><TR><TD CLASS="quote">
Damn, when did a 13.5:1 LS happen?!</TD></TR></TABLE>
All I need is to assemble and buy 255 walbro fuel pump and I will be back running again. Hoyt is raising his CR also. See ya at Shady!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">
You are rebuilding your LS? What are you using to get 13.5:1?</TD></TR></TABLE>
PM me for details!
PM me for details!
Can't wait to see it, are you going to still daily drive your car?
</TD></TR></TABLE>Can't wait to see it, are you going to still daily drive your car?
hybrid_vtec
15
Jul 30, 2004 01:37 PM
